5R110W pan upgrade on 2005 E350 V10
I have a 2005 E350 with the V10 and I am considering upgrading the oil pan. I see folks are using the pan from the 2008 and up 6 liter diesel and want to double check that that will work for my van. I am pretty sure I have the 5R110W transmission, it has the tow/haul switch on the shift lever. I like the idea of having a full flow filter in the pan, but don't really know much about it. I have done some overweight towing in the past and never had any problems with the transmission, and I only tow light loads now. I sometimes have trouble on parts websites because my VIN comes up with various body styles. It is a 15 passenger van XL Super Duty.
Thanks,
Jack
Thanks,
Jack
I wouldn't pay that money for an aftermarket pan. The only benefit from those pans is the bottom of the truck looks pretty.
The later 2008 factory pan is a little bit larger. The reason to change to that pan is that the 2008+ filter is a MUCH better filter than the earlier filters. It's even finer than the aux filter that came with the earlier trucks. The later filter won't fit in the earlier pan.
Back to school then Mark
1ole4d
06-06-2002 10:15 PM
