Outside Mirrors, any decent aftermarket ones out there
Old 10-29-2024 | 11:23 AM
Starliner1955's Avatar
Starliner1955
Geeze, the crap that's out there.
original
Original
Aftermarket
Aftermarket
As you guys know, the stock mirrors start deeper from the inside oart, and taper in as they also towards the outside end.
Plus, originals were heavier, made of better metal, and held their settings.
Do you know of any aftermarket ones that don't suck?
Thanks
Old 10-29-2024 | 02:08 PM
Franklin2's Avatar
Franklin2
No. Your best bet is the salvage yard. Many of the aftermarket ones are plastic.
Old 10-29-2024 | 05:08 PM
FuzzFace2's Avatar
FuzzFace2
I am running LMC ones, normal glass both sides as I was going to pull a trailer and the right side convex is not good for trailer towing.
They have been on the truck 5+ years now but the truck dose not stay outside when home but is driven a lot even in the rain like we had last Sunday and got the truck dirty
Now I will say the ball / socket is pretty loose so will not hold but you cant go to tight or when you need to adjust the ball will snap off the screw part base
What I have done is adjust them where they need to be and then using a normal & 90* screw drivers, only a 90* can get to some of the screws, and tighten them.
If it is not right depending how tight you went on the screws you may want to loosen them, adjust and tighten back up.
The right one of mine moves and I need to go a little tighter so it will stay put as I do pull a trailer and need that mirror.
Dave ----
Old 10-29-2024 | 11:40 PM
Starliner1955
These are at a junkyard.
i think that they are factory to mirtors that have the same 2-point mounts as my other regular stock one.
If so, this might be good since I use the truck mostly for towing my boat and trailer.
1955 Lonestar
1955 Lonestar
Old 10-30-2024 | 07:33 AM
Bronco638's Avatar
Bronco638
Originally Posted by Starliner1955
I've owned a Bull Nose, Brick Nose and OBS trucks. I'm pretty sure that these mirrors were used on all three generations. So, like @Franklin2 said, a junkyard is your best best. Check Car-Part.com. Maybe you can find a nice set from elsewhere and have them shipped.
Old 10-30-2024 | 08:46 AM
Starliner1955
Yeah, been looking on car-part.
they are great.
Thanks
Old 10-30-2024 | 10:06 AM
BigBlue2's Avatar
BigBlue2
1955 Lonestar
1955 Lonestar
I like that boat! Is it aluminum? 1955 Lonestar? Built in Texas I assume?
Ford did offer some larger trailer mirrors. I've seen them in the old brochures. Grab em!
Old 10-30-2024 | 10:11 AM
Starliner1955
Correct.
i completely redid it after finding it at an abandoned boat yard. It had been sitting for 30 years.
It only weighs about 1000 lbs.
I love the boat.
lots of good times.
Lots of overnights with some Cap'n Morgan at the helm.
Old 10-31-2024 | 08:12 AM
Bronco638's Avatar
Bronco638
@Starliner1955 My favorite junkyard (Southwest Auto Salvage in Lockport, IL) has a set on an '87 F-150 (white - stock # 190306). I may be taking a run down there before Xmas. Are you in a hurry? What's your budget?
Here's the mirror criteria (for the secondary search): Manual, 2 mounting points (swing lock, 4 bolts), chrome (5x8"), LH
Old 10-31-2024 | 09:03 AM
Starliner1955
Wow, that is a very generous offer.
I decided to go with the tow-style and pray that I can attach them to the existing mounts. I think it will work.
I ordered just one to see if they will work.
I will let you know!
Thank you.
Old 10-31-2024 | 02:49 PM
Franklin2's Avatar
Franklin2
That bottom bracket that bolts to the truck; It fits a little ranger pickup also. I had some sort of sport mirrors on my old ranger and they flopped around all over the place. The top two bolts lined right up with the larger mirror brackets off a f150 and I just had to make two holes in the ranger doors for the bottom two bolts.
Old 10-31-2024 | 03:03 PM
FuzzFace2's Avatar
FuzzFace2
You may need to make an extension to get the head up above the door bracket.
If you look at the first picture and the one you ordered the round part is longer in the first picture and I think when you turn the mirror in to where you can use it the head will hit the door bracket.
I want to say early Chevy used a mirror like you are looking at but had the longer round part?
Now if you do need a longer round part I would get some conduit cut to what you need and weld the bolt in 1 end that will fit the mirror and get a nut & bolt and weld the nut in the other end.
You then screw the extension onto the mirror and then bolt the assy. to the bracket on the door.
You also know I think Ford had brackets where you unbolt the mirror head and bolted on a extension and the mirror to it.
I believe they would be in a little closer to the door and then turn them out when needed.
Kind of what MAX? has on his.
You can also find a different type on Ebay that slide in & out on a bracket. I think when in they are out just a little bit than if mirror was bolted to the door bracket.
I have a set of this type but have not had the need to mount them as the trailer I pull dose not block what I can see behind me for the most part the short distance I tow it.
Dave ----
Old 10-31-2024 | 04:55 PM
Starliner1955
Dave,
I am going to the junkyard tomorrow to look at these for each.
I hear ya on tube length. I could have ordered longer, so if I need to go that route, I am ready.
wish me luck at the junkyard. I have other things on my wish list!
Joe
Old 10-31-2024 | 08:52 PM
BigBlue2's Avatar
BigBlue2
1955 Lonestar
1955 Lonestar
I have a few questions about your starliner. What's the beam? I think I see a steering station after side of the cabin. Is there one inside too? What engine do you use to push it? Top speed? Thanks, Blue...
Old Yesterday | 08:36 AM
capijuan's Avatar
capijuan
I just started another thread looking for mirrors like this. Where did you find them and what are they called. I would like them for my 82 F250 plow truck. Backing up in the snow and in the dark on a curvy driveway with drop offs using the smaller mirrors is a bit dicey.
Please keep us posted if they work.
Thanks
Quick Reply: Outside Mirrors, any decent aftermarket ones out there
