Glow plug bypass issues
Old 10-02-2024 | 09:25 AM
seanres's Avatar
seanres
83' 6.9 IDI w starting issues, had clicking issue when switched to on and hard starts but started well with ether. New glow plug relay solenoid, new glowplugs, new injectors. Currently using a fuse jack on the radio fuse but still having some weird issues and no starting. Took a video of the voltage on the battery negative and right post which the wire is connected to, and the voltage changes as follows: 0v to 11.8v when turning key from off to on, then staying at 11.8v when pressing the momentary switch and while holding for 3s voltage drops to .15v , then drops slightly to .12v after releasing the momentary switch after 5s. Am I wasting my time with the fuse jack and should just be wiring directly from the positive terminal with a fuse? Not sure what else could be causing the issue.
Fuse tap from radio fuse
New glow plug relay
Momentary switch between fuse tap and glow plug relay
Old 10-02-2024 | 11:44 AM
WCMtn1990's Avatar
WCMtn1990
Not sure about using a fuse tap because I did not need that for my manual GP setup. I followed this article exactly and 8 years later no problems, https://www.oilburners.net/articles/glowplugbypass.htm
Old 10-02-2024 | 12:32 PM
seanres's Avatar
seanres
I was originally using this video as a reference which was for a 6.9 relay, the right post is wired to the momentary switch which is then connected to 12v from the fuse panel
The link you sent is for the 7.3 controller, in that setup the switch is grounded to the frame, did you follow this for a 6.9 or 7.3 controller?
Old 10-02-2024 | 01:50 PM
WCMtn1990's Avatar
WCMtn1990
7.3 controller yes but the solenoid should be the same. Yes I grounded my momentary switch to the frame. I also ran my own glow plug wires because the factory harness was in a state of doo-do and not worth fixing. The only reason my controller is still on the truck is because the solenoid mounts to it. The fuse tap might be lame but I've never used one. I suppose your trigger wire could be just about anything with key-on power. For an unrelated issue I tapped into the chime module to trigger a relay--not sure if an 83 had a chime module.
Also, you might try crimping some female spade terminals so you get a better connection at your switch.
Old 10-02-2024 | 02:49 PM
seanres's Avatar
seanres
Just updated the connections to female spade and used the positive connection from the same location in this video at 23:46 to the right of the yellow fuse
So I know my power location is correct but I'm still not getting any wait to start light, when I check the voltage of the terminal it is now correctly going to 12v. No start after holding for 5s and trying to start
Old 10-02-2024 | 02:55 PM
WCMtn1990's Avatar
WCMtn1990
Originally Posted by seanres
Just updated the connections to female spade and used the positive connection from the same location in this video at 23:46 to the right of the yellow fuse https://www.youtube.com/watch?v=JODAGSVBVNc
Does your voltmeter twitch when you activate your momentary switch? It should move when current is applied to the plugs.
Old 10-02-2024 | 03:20 PM
seanres's Avatar
seanres
Yes, it seems the switch is working correctly. I am also having a slow cranking issue and though I fixed the starter connection earlier it has still seen better days.. going to grab a replacement and replace some of the messed up battery terminals to eliminate any other issues. Using two new batteries w/ 12.8 voltage when off
Old 10-02-2024 | 05:33 PM
WCMtn1990's Avatar
WCMtn1990
Yeah my starter seems to be slowing down despite batteries at 12.9 and oversized cables. There's always something else to fix.
Old 10-03-2024 | 04:42 AM
tjc transport's Avatar
tjc transport
i ain't rite
what brand glow plugs did you put in it?
these engines only use motorcraft plugs, all others are garbage and will burn out after one start most of the time.
when bypassing the glow plug controller, i run12 volts to the relay and switch the ground wire to activate the relay.
Old 10-03-2024 | 10:18 AM
seanres's Avatar
seanres
Interesting, I have not seen that setup, was that for a 6.9 controller? Mine is 0v, 12v when holding momentary switch on the right post now that its working. I got new ZD-1-A motorcraft plugs per the recommendations on this forum for that exact reason so they should be good.
Old 10-03-2024 | 11:15 AM
tjc transport
i ain't rite
No controller. Relay only. I switch the ground not the power
Old 10-04-2024 | 12:38 PM
seanres's Avatar
seanres
I see, is there any particular reason it would be better to do it that way?
Old 10-04-2024 | 02:48 PM
tjc transport
i ain't rite
So if the wire from cab to relay shorts out, there is less chance of the wire causing a fire and burning the truck up
Old 10-07-2024 | 07:57 PM
seanres's Avatar
seanres
Starter and starter solenoid came in, but realized that it had a 3 post starter solenoid beforehand. New solenoid didn't work until I used a black wire which was originally on the mounting plate of the 3 post starter to the back plate of the new starter solenoid. Jumped it w screwdriver on a single battery at 11.8v and sounds like this.. didn't put new starter motor in yet but not sure if what I am hearing is just a result of bad starter + lowish battery (which I am recharging in the meantime). Any thoughts on what the issue could be or if I messed something up with the wiring?
Video of jumping starter solenoid:
Old 10-08-2024 | 04:36 AM
tjc transport
i ain't rite
that is either low batteries, or bad starter. or both.
The following 2 users liked this post by tjc transport:
Quick Reply: Glow plug bypass issues
