I'm new and don't know what to do!
Possible EBPV connector, most dont use it since it make a hissing sound when starting up.
Welcome to the club, no member ship fees are required, just some pics of the beast!
Just be you and have some fun fixing.
so-you-bought-a-new-to-you-diesel-truck
https://www.ford-trucks.com/forums/1...sel-truck.html
get a new boot on turbo inlet, thats an old one prone to fail which will dust your engine
https://www.riffraffdiesel.com/riffr...nd-y-boot-kit/
If you decide to keep it off or even go with the deleted pedestal that quite a few use Riff Raff diesel sell a plugin https://www.riffraffdiesel.com/ebp-p...pigtail-94-97/
It will stop you from throwing code. I use one because I cant stand CEL lights or stored codes.
NO CEL is shown on OBS, there will be a code when scanning
SD does need a resistor or you get CEL
Deleted pedastal is a PITA unless you taking the turbo off for some reason, mine is on a shelf still for 7+ years
IMO, remove down pipe at turbo, grind off the two rivets and remove the flapper valve is a simpler method to remove it.
I ended up wiring mine open with a coat hanger, took 2 minutes and done. Mine will close even with electrical connector removed.
the_real_zekenator
01-18-2024 01:22 PM
99.5_Superduty
11-15-2021 04:53 PM
MikePacey
30
09-05-2011 04:52 PM
