6r140 pan has no drain plug!
I’ve seen other trucks with a drain plug for the 6r140 (2018 6.7L), but mine requires that I drop the pan to drain the fluid. Why the hell would a manufacturer spec that change? Now I have to spend $3-400 for an aftermarket unit or find one off a wrecked truck. Have you all found a cheaper (and cleaner) solution? I already have a cement mixing pan to put under the truck and catch the mess but sure would rather simplify it down to one bolt removal, or better yet, a twist valve
![Wink](images/smilies/wink.gif)
The following 3 users liked this post by 6.2caribou:
![Confused](images/smilies/confused0082.gif)
Drop it once - install this, drain from then on.
B&M 80250 Universal Transmission Drain Plug Kit
https://www.ebay.com/itm/115544304929
The last ford product I had w/ a transmission drain plug was a 1998 Cobra w/ Borg warner manual 5 speed. My last truck (2011 F150) didn't have a drain plug plus the fill port/ dipstick was right next to the catalytic converter so if you blinked while checking the fill level you burn your wrist. The burn and last trans service on that truck made me so mad that I read the transmission service procedures for GM and Ram before buying my F250. Spoiler alert, they all suck.
The following 2 users liked this post by cpobst:
