F250 5.4 2v supercharger
Justin,
From my research years ago on this subject when I had a 5.4 in my 2003 F250, the stock Lightning supercharger is too tall to fit under the firewall of the Super Duties, so extensive modifications would have to be made. I think that most guys that end up supercharging their Super Duty use a centrifugal supercharger. I'm not sure if there are any full kits available or if you have to piece something together.
This is her
ready to bolt up accesories
this is an allens engineering eaton m90 sc kit for my 5.4 2v. Fits snuggly but it fits non the less. Stock at 6lb but i turned it at 12lb for about 5000miles before i decided to pull it down to do the bottom end strengthening. Had some issues with tuning but man it pulled and the blower whine was awesome. Im 10000miles in now after build up with a 6lb pulley and about tto go back for a custom tune at 12lb. Its intercooled and has a seperate blower cooler as well. 🤙
The kit was purchased from a wrecked truck a few years back in crested butte and i got it sent to me in Australia. i found the installation manual for it online then refurbed bits as i installed it. The kit came with 2.5inch pulley so turned 6psi. It didnt require any fuel system upgrades etc. It was pretty much bolt in with a bit of light fabrication and relocating alternator etc. When we turned it at 12psi i went to 39lb injectors larger fuelpump and 4bar reg. As well as 90mm maf and added an external iat sensor as 90mm maf didnt have it. Also genie headers and 4inch exhaust. Because of the extensive mods i gave it to a local ford tuner to run it on his dyno but he had issues with a driveable tune at low rpm. We got 296kilowatts at the rear wheels through big rubber which i was pretty happy with. I guess when its left at 6lb my mileage was actually a bit better. 12lbs and bigger injectors hahahaha not so good lol. But it was a hell of a lot of fun and man the blower whine was awesome. I pulked it down for a full bottom end and heads build and have just gone thru 10000miles at 6lb with a safe tune. Its booked in at another dyno guru in august to really dial it in at 12lb again.
Allens engineering i believe closed up shop mid 2000s ? Its az shame because this is a great little bolt on sc kit for the 4.6 and 5.4 2v
The following 2 users liked this post by McEntire:
