1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Blend door problem
Old 09-28-2010 | 11:01 AM
dirtduck48's Avatar
dirtduck48
Blend door problem
Got a 08/250/64k/6.4/duel heat air.I think the driver side blend door won't operate. Passenger side goes from hot to cold,driver stays on ac.
#1 can you manual move door
#2 is it vac. or elec.
#3 any place i can get diagram or drawing of heat assy.
or how to get to it
Thanks for any help
Old 09-28-2010 | 11:05 AM
gearloose1's Avatar
gearloose1
Do you have a vacuum problem?
Old 09-28-2010 | 11:13 AM
dirtduck48's Avatar
dirtduck48
Don't think so. Pass. side door works,4 wheel works,pump runs and stop correct.
Old 09-28-2010 | 11:22 AM
gearloose1's Avatar
gearloose1
If vac verifies with a gauge.
Then, start looking for a break in the hose, a bad actuator, or...
Have you consider the possibility someone threw crud into the "hole" and jammed it?
When I cleaned out my vents, I found, pens, pencils, and misc. garbage throughout the ducting.
Tyler Heleine
6.4L Power Stroke Diesel
04-17-2014 11:31 PM
dlgfords
1997-2006 Expedition & Navigator
10-19-2011 10:35 PM
rcorcich
03-26-2010 07:38 AM
ab257z
10-19-2008 04:38 PM
sc93f
02-13-2004 10:54 PM
