1978 - 1996 Big Bronco
Is this Coolant Tank "Leak" actually a LEAK?
Old 09-16-2010 | 01:43 AM
seedpress's Avatar
seedpress
Does anyone know whether the coolant reservior (overflow tank) is pressurized or not? In other words, does it vent to ambient air pressure, or is it sealed up to some pressure point? I have an '90 Bronco 4X4 with the 5.8 liter engine, Eddir Bauer Edition; however, I think a broad range of years and models use the same overflow tank.
The reason for this question stems from a coolant leak that keeps appearing on the fender underneath the coolant tank. I can feel the coolant dripping from the bottom of the tank after the engine has been running a while. I'm pretty sure it hasn't been coming from the hose and nipple. (Earlier, I had a problem with it sloshing occasionally from the refill cap. The cap had become loose. So I fixed that.)
In an effort to find the new leak, I removed the tank and submerged it in some water. The refill cap was oriented at the bottom of the water, and the hose nipple at the top. When air pressure was appled through the hose connection, then, sure enough, bubbles came out of an area pictured here:
Note the messy hot glue I've added to the area that was formerly "leaking" air. This was done in haste -- after I saw the air bubbles. Now nothing leaks, but it has since occurred to me that perhaps the "patched" area is actually supposed to let air out. Hence my question about the pressure.
The tank seems to be made of polyethylene, which is difficult if not impossible to glue. Nevertheless, the hot glue that was used to plug the air "leak" seems to be adherring -- for the time being. But I could probably peel it back off, if it turns out that I shouldn't have plugged that area. Then I'll still be left with a leak. And after the area pictured was sealed, there were no more air leaks, so I am assuming the coolant drip was somehow coming from that area, though it's at the top of the tank, and I haven't overfilled the tank.
Anyway, is that tank supposed to be pressurized or breathable?
Old 09-16-2010 | 05:41 PM
Torky2's Avatar
Torky2
Not pressurized, except for a momentary surge when the radiator cap pressure is exceeded and A/F burps into the tank.
The tank is vented at the cap or on a top edge. Air needs to be able to go in and out of the tank... out when A/F expands and flows into the tank, increasing the fluid level. And air into the tank when the engine cools off when parked, and A/F contracts, returning A/F to the radiator via the vacuum relief valve on the bottom of the radiator cap.
Glueing Poly requires a special glue. It is used on RV water tanks. Used to be a little foil packet that you moosh around to mix. Have to clean and roughen up the surfaces to be glued first. Try an RV supply place for the glue.
Hot melt was just for testing, I assume, as hot A/F will soften the glue again.
kr98664
72
02-28-2024 12:27 PM
bsetbuilding
05-21-2020 06:39 PM
guitar_199
1997 - 2003 F150
10-18-2010 08:34 PM
enikolich
06-17-2010 02:22 AM
koalamazed
Aerostar
03-12-2006 10:57 PM
