Finding all of the ground points
I've been cleaning grounds today. The one on the passenger side battery was easy.
The transmission ground had never been done but was also pretty easy. I would say that the cable there was a lot narrower than my last vehicle.
The one from the driver side battery disappeared into 1/4" of gunk a bit south-east of the water-pump. When I got a lot of that cleaned out, it seemed very shiny underneath all that and I am thinking about leaving that one alone. It's a little trickier to get a wrench into there behind a main coolant hose, with some other small diameter lines connecting to something else right there too.
Are there any other ones I'm missing? Did I trace the one from the driver side battery correctly?
and duhh-huhh, I forgot to mention the heavy gauge ground coming off the passenger side battery. this goes on down to the frame to a bolt not that hard to pull off, but wasn't all that dirty neither. however right at the connection a small gauge wire runs back to yet another ground point on top of a long-wise bar of the frame. this little connection point sits right under one of the big lines coming out of the turbo (I've never understood what those two y-ed lines coming back out of the turbo do ... exhaust? air overflow? need to learn more about this). anyway if you had that line off the turbo it would be a good time to get this little ground point too, though it likely isn't that dirty in such a non-exposed location. the big hot wire to the starter hangs just above it too but isn't really in the way.
oh and for future reference that wasn't quite a 'transmission' ground...it was just a cable from one part of the frame to another, not connected to the trans at all. I projected that idea onto it from another vehicle. haven't noticed one connected to the trans yet, need to look around again I guess.
cadunkle
10-17-2016 08:46 PM
jayro88
07-16-2016 12:47 PM
The Last Nut
1997-2006 Expedition & Navigator
09-13-2015 02:17 PM
