Radius Arm Bushings
Old 08-31-2010 | 10:05 AM
Roller150's Avatar
Roller150
Radius Arm Bushings
What is the best way of replacing the rear bushings?
Old 08-31-2010 | 10:10 AM
coz's Avatar
coz
when I did mine I had to push on the front axle with my foot to allow room to slide on the new bushing. Just be safe.
Old 08-31-2010 | 10:14 AM
Roller150's Avatar
Roller150
It moves that much to where you can take the old ones off and put new ones on? How hard is it to get back on? Can the bracket be taken off at all?
Old 08-31-2010 | 10:36 AM
coz's Avatar
coz
Mine did. you may need a buddy to help you. The radius arm brackets are usually riveted on. I didnt have to remove mine on the 3 or 4 i`ve done.
Old 08-31-2010 | 10:50 AM
Roller150's Avatar
Roller150
10-4 I will try that then. Thanks
Old 08-31-2010 | 12:58 PM
Grubbworm's Avatar
Grubbworm
When I replaced my radius arm bushings, I used a come along. I jacked up the truck (jack-stands under the frame). Jacked up the wheel and removed the tire. Then I removed the lower shock bolt, and lowered the jack all the way. Then I removed the retaining clip that holds the top of the coil spring. And the coil spring comes down (still attached at the bottom).
I removed the nuts holding the rear of the radius arms on. I attached a come-along to the front I-beam/axle and to my lawn tractor. I pulled the slack out and pulled the radius arm forward enough to get the bushings off.
Once I had the new bushing installed,
I attached the come-along between the front I-beam/axle and the rear axle. Then I used the come-along to pull the radius arm back into position so that the other bushing could be installed.
Then you can put everything back as it was. Good luck, I found it was not as difficult as I had imagined it to be. Let us know how it turned out. And post some pictures.
Old 08-31-2010 | 01:17 PM
berry1234's Avatar
berry1234
I drilled out the bracket rivets, put on the forward bushing, reinstalled brackets with grade 8 bolts, then rear bushing, nut. Come-along works too.
Old 08-31-2010 | 02:11 PM
91Bronc300's Avatar
91Bronc300
I used a carbide burr on a die grinder to remove the rivet heads then reattached the radius arm brackets with grade 8 hardware and a dab of loctite when done also.
Old 08-31-2010 | 02:23 PM
Blown 331's Avatar
Blown 331
Did all years have the brackets riveted on? My 1977 is bolted. I know the 78/79s were riveted but I'm not quite as familiar with the 77s even though that is what I have. lol.
I'm just wondering if someone has been in there already or if the 77 is bolted from the factory.
I just finished up changing the radius arm bushings at the other end, the C-bushings. Thats not the most fun I've ever had. haha. I installed 7* C-bushings from Bronco Graveyard.
Old 08-31-2010 | 02:26 PM
berry1234's Avatar
berry1234
My 78' had one or two rivets and the rest bolts from the factory.
Old 08-31-2010 | 02:46 PM
jb10's Avatar
jb10
i just did this on mine back in march/april.
i replaced all the bushings on the front end, the shocks and the coil springs with buckets. at the same time i coated most everything with chassis saver.
i jacked up the front. put it on jack stands and when it was time to remove the radius arms i was able to simply roll the front axle.
it was very easy.
i have a 78 f150 4x4 and the radius arm brackets were bolted on. at the time i also had a 77 f150 4x4 and they were riveted on. i actually had to swap one from the parts truck as one on my truck was bent.
Old 08-31-2010 | 11:37 PM
Roller150's Avatar
Roller150
Grubbworm, did you do both at the same time or do you do one side at a time? Thank everyone else for their ideas as well.
Old 09-01-2010 | 12:32 AM
tinaheels's Avatar
tinaheels
on my 79 i unbolted the bracket after undoing the big nut
Old 09-01-2010 | 09:17 AM
Grubbworm's Avatar
Grubbworm
I basically did both sides at the same time. I did loosen everything up at the same time and then installed the bushings one at a time. Then tightened everything up at the same time.
289 sprint
1966 - 1977 Early Broncos
04-09-2015 09:45 PM
newguy399
08-06-2013 04:13 PM
dieseldodgeguy
07-28-2013 11:37 AM
lakex1
07-27-2005 08:41 AM
Mexray
1978 - 1996 Big Bronco
04-06-2002 05:47 PM
Quick Reply: Radius Arm Bushings
