need help againe
I think there are 2 fuse blocks under the hood, there should be a smaller one more towards the fire wall that has the trailer fuses in it. My truck is not here so I cant look. If you have the owners manual check there, it should tell you description/ fuse locations.
The only other thing I can think of is it has the wrong bulbs, or the connectors are corroded, but oit doesnt sound like it cause the parking lamps work, and the directionals work.
Sarge
Sarge
brake lights
I found the problem. It has to do with the multi function swith in the steering colum. I pressed the hazerd switch a few times and the brake lights went back to working. I thank it has to do with the amount of dirt and dust that gets down in there.HEY THANKS FOR ALL OF THE HELP AND SUGESTIONS
