Restoration questions
I would have them chek real good for rust in the usual places.
1. lower cowls
2. cab corners
3. radiator support under headights
4. drip rail/rain gutter (check from inside)
5. floor pans between kick panel and cab bolts.
6. front cab supports
These are real bad about rusting.
1. lower cowls
2. cab corners
In addition to the spots Krosati mentioned, have a look at (look at it with a hammer!) the cross sill under the cab. After I fixed mine I drilled a 1" hole at each end to allow better drainage. You'll see where I mean. Also, there is a cavity behind the kick panel that is inaccessible unless the kick panel is removed. If there's no rust in there you don't have to worry. If the kick panel is rusted through, or there is rust at the seam between it and the floor, you might want to look in there.
I also drilled 1" holes at the bottom of the cavity under the vent door. These can be plugged with vinyl plugs. And - don't take this the wrong way - after you've sand-blasted the bottom half of the cab, inside and out, the trouble spots will be easier to see.
Eric D
Eric D
1960truck
30
05-06-2010 01:48 AM
Manic_Mechanic68
12-04-2009 11:19 PM
ArcadeTom
15
11-18-2007 04:03 PM
