2005 Expy vacuum line question?
Hi folks, a few days ago my vent control started going wacky, and I could hear a vacuum whistle under the hood. I traced it to this T fitting just behind the battery box (between the battery box and firewall). It appears it should be connected to another line, or perhaps capped? I've looked everywhere around it and can't find any disconnected lines.
It's a 2005 Expedition.
Many thanks in advance !
The pic below shows another angle where you can see the other T (black) just next in line to the white T.
On a side note, I temporarily plugged that white T and the vent control seems to be working fine. But I'm not sure if I've left vacuum off for somewhere else by capping it.
You very well could be right, as I've had vent problems in the past on my F250 when the ESOF vac line had a leak. Didn't remember that they offered the Expys with 4WD.
I have taken my 2005 expedition in to have a fuel system cleaning done.. I have taken it to two separate places, and neither can seem to find the intake vacuum line that is needed to do this work. Any ideas as to where I can obtain a diagram, and or instructions as to where this valve is, so as to be able to get this service done on my vehicle..
Much appreciated in-advance.
If you're looking for the fuel pressure regulator vacuum hose it is on the fuel rail above cylinder #4. If they just need a large vacuum hose then they should use the one going to the brake booster. However, IMO if a shop cannot find something as simple as either of these vacuum hoses then they are a pretty lame shop and I would be highly reluctant to have them touch my vehicle.
2005 exoy vacuum line question?
First thank you for your response, and second.......... I was having just that very thought. I thought at-least I would try to find out where it was located. At worst I might-could figure out how to service the fuel system myself.. Thus wouldn't mind finding a diagram.
xjcamaro89
2004 - 2008 F150
448
07-26-2024 01:35 PM
geocraig77
2004 - 2008 F150
12-19-2011 09:34 AM
