1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F 450 transmission problems
Old 06-29-2010 | 03:39 PM
Erosion Man's Avatar
Erosion Man
My 2004 F 450 will run thru the column, up and down, the linkage on the side of the tranny moves accoardingly, but it will not engage in any gear, just happened out of the blue. No proir problems with anything, no slippage etc. pulled a skidsteer to my shop, turned the truck off, restarted it in the a.m. won't move, any one had this problem and a possible remedy.
Old 06-29-2010 | 05:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
The remedy is usually pull the trans out and rebuild it. There's a very slight chance that the linkage disconnected inside the trans, but that's rare. Most likely something mechanical broke and it's toast.
Sorry.
Old 06-29-2010 | 06:01 PM
Erosion Man
Not it, Third time it has happened over a period of a year.
Old 06-29-2010 | 06:06 PM
merccougar93's Avatar
merccougar93
Ah, same thing has happened in my dads f350. There is several things that i have read that could be the problem, such as a mechanical diode. i cant remember all the things that could be wrong, but it all leads to a rebuild.
Old 10-03-2024 | 03:52 PM
CurtW0644's Avatar
CurtW0644
1st Gear
I thought I was having transmission issues due to this whining noise when i pressed the throttle. I was told i needed to rebuild my tanny. Im glad i took it to Ford instead of this transmission shop because it was a pully.
javier87
06-05-2017 04:27 PM
Jose Betancourt
Projects
11-04-2016 09:06 PM
speakerfritz
08-05-2016 07:59 AM
Mike_123
Fifth Wheel & Gooseneck RV Towing
07-08-2016 04:14 PM
johnbrown
Large Truck
03-07-2011 06:09 AM
Quick Reply: F 450 transmission problems
