6.0 won't crank
#31
havent tested resistance. Why is that important? Yes the dash lights all come on just like normal key on. Yes I used the fuse box for 12v ignition power with a fuse adapter. Yes bth relays have power and for good measurre we swapped them and also jumped the relays to ensure power.
But like I said the pcm harness has all its power and grounds witch is after the fuses and rlays according to the schematic.
#32
ok so you checked power at the relays, what about the grond side? are they getting the signal from the ingnition swich to get ground.
if you check pin 6 and 13 like I said you will have either 0, 60, or 120 ohms.
this tells you weather the pcm and or the i/c are off the network line.
did you just check the fues with a test light? or did you pullk them out and look at them like you should?
check fuse f2-22 20amp (i think) pull it out and check it.
#33
THE FIX
I saw a post today about posting what fixed your problem. After reading I realized that I am as bad as anyone when it comes to fixing the problem and not replying anything else. I guess its the kid in us, we fix it and we have to go go go. So my solution wound up being one wire shorted to the intake. There are 2 communication wires that run between every module on the truck You lose one the truck will not "see" anything PCM, TCM, Glow Plug, etc, I dont know the exact color or anything but it is all in the schematics. After finding no problems in fuses, relays, batts, etc. it came down to tracing wires. The wire was in the big bundle in between the fuel and oil filter, under the intake tube, in about a 1 inch conduit. Fixed the short and all is well. The only thing I may have done to disturb it was reaching back to unplug the ICP to tap into the wires for the HPOP gauge.
Hopefully this helps some one sometime.
#35
#39
#41
wont crank
new to this forum i have been reading the above i have a similar problem i have a 2005 f250 with the 6.0 i tried to install sct livewire on my truck i downloaded the program and now my truck wont start i tried to download back to stock and it still wont crank everything work but it wont crank and fuel pump is not coming on. check all fuses and relay check for power to pcm i have it but no ground, any help would be greatly appreciated
#42
