1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Adding a rear sway bar
Old 06-08-2010 | 04:47 PM
grec-o-face's Avatar
grec-o-face
Anyone have any first hand experience with an added rear sway bar for SRW trucks?
My 'search' button doesn't net very much - hoping for some input here. I'm thinking about adding one in hopes of a better highway truck with less wander and less body lean. How about towing... must help there too, right?
I know Hellwig sells 'em, but they're like 250 ish.
Thanks All.
Old 06-08-2010 | 06:34 PM
LMS Residential's Avatar
LMS Residential
I installed the hellwig rear sway bar on my 08 about a year ago. Dramatic change; truck tracks nearly flat even in hard cornering and feels like all 4 wheels are steering. No body roll whatsoever, it even helped correct the bump steer and occasional wheel hop I was experiencing.
For best results change to a mono max type gas shock at the same time, may firm up the ride for a while but feels like the truck is stuck to the road with glue. The hellwig is worth the few extra bucks, poly bushings supplied and doesnt even have any surface rust after a year.
Once you get pi**ed off enough to toss the useless instructions, the installation is straighforward and actually pretty simple. I cant stress enough the importance of getting under the vehicle with the components and holding everything up in place to get a good idea of its' orientation. All of the necessary holes are there in the frame and its easy to see how it saddles to the differential. Use the instructions ONLY as a basic recognition of parts and the finished assembly. The rest is gibberish.
The truck also stays tracking much better when towing or loaded, even in excess of its capacities.
Old 06-08-2010 | 10:07 PM
wallz's Avatar
wallz
Lots of guys/gals add them over in the Xcursion forum, and yes they do make a big difference. Most add them the same time they replace the shocks, so it is a little harder to say how much difference each makes. For those that tow they look into either air bags or RAS system. Do a search in the X forum for towing or wander and you will see lots of threads on these issues.
Old 06-08-2010 | 11:20 PM
DAVE67FD's Avatar
DAVE67FD
You could try your local Ford parts dept or "Ed" parts guy here on the forum. (he has a different signature now, not sur what it is) or your local junk yard from a donor or wreck.
Price new may be close to the hellwig. Not sure if they had the option in 02, or similar year should fit.
Old 06-09-2010 | 08:36 AM
grec-o-face
Yeah, if the price of a new factory set-up is close to the Hellwig, thwn I might as well go with the aftermarket and get poly bushings and a larger bar.
I'm goning to call my ford parts dept just to see.
rjoseph1960
2017+ Super Duty
334
06-28-2021 04:32 PM
BIGTRUCKBIGRV
6.7L Power Stroke Diesel
39
08-20-2017 09:48 PM
hurst1979olds
08-08-2017 01:13 AM
mosquito13
09-12-2016 07:02 PM
postman524
01-22-2011 01:56 AM
