tfi wire diagram
Old 05-14-2010 | 10:50 PM
tnfarmer67's Avatar
tnfarmer67
tfi wire diagram
i bought a f150 4x4 about 5 yrs ago and it came with a 302 , the truck was originally a 6 cylinder truck. i'm swapping it back to a 4.9 and the one i have has the tfi ignition on the distributor. my wiring harness is in pretty bad shape, i need a diagram for the tfi. i'm going to use a points distributor til i get a diagram. i wanted one wire dist. but i'm not going to spend $400.00 ill just have to have less power with the points. i only use the truck to pull my boat .any help ould be appreciated
Old 05-15-2010 | 01:48 PM
JimsRebel's Avatar
JimsRebel
Will you have to change the computer if you stay with the TFI?? Is a 302 the same as a 4.9 computer? Carb or EFI engine? what year truck?
I would just use a duraspark dist and a ignition module of your choice.
Cheapest would be a GM 4 pin module.
Dirt cheap Ignition
Old 05-15-2010 | 10:03 PM
tnfarmer67's Avatar
tnfarmer67
the 4.9 came out of a 86 and i'm putting it in a 85 and its is a carb. the dirt cheap ignition looks really good. update, i was tring to install the 4.9 but needs motor mounts they wont be in till monday
Old 05-15-2010 | 10:35 PM
JimsRebel's Avatar
JimsRebel
cheapest dist is on ebay for $55,with cap and rotor and free shipping, that is where I got mine... but it only lasted 2000 miles before the roll pin on the gear sheared, the gear is still in the bottom of my oil pan.
Photos of mine.
Old 05-16-2010 | 12:27 PM
tnfarmer67's Avatar
tnfarmer67
i see you have two of the gm 4 pin modules ,i'm guessing there is an extra one just in case one fails. and if it is how often do they go out. i have a duraspark dist. in a spare engine so thats definitely what i'm going to do. and the heat sinks you have did you buy them somewhere or did you make them . i have some 1/4 inch aluminum if i double it should be enough. thank for the info
Old 05-16-2010 | 12:50 PM
JimsRebel's Avatar
JimsRebel
The heat sink is from a computer CPU, my local computer repair shop sells used ones for $1. I cut the heat sink in half (was square) and the 4 pin modules are junk yard used stuff, so it was just as easy to make an extra spare while I was at it. If the 4 pin module is heat sinked well it wont have any failure issues, heat is the only issue. I have beening running this setup for over 2 years without a failure. But I DO like having spare parts on hand, ready to go. Use heat sink compound under the 4 pin module, the auto parts store will sell it.
NAPA OnLine sells the 4-pin HEI ignition module, ECHTP45, for ~$39 + shipping. These are also widely available as Wells DR100, Niehoff DR400, Standard part numberLX-301 (~$28); or AC DELCO D1906 (~$33), and were used on many non-computer GM V-8s, V-6s and I-6s from 1975 to the mid 1980s. <O</O
Old 05-16-2010 | 01:58 PM
snickersandapepsi's Avatar
snickersandapepsi
awesome use of a CPU heatsink.
The next time i crack a beer open i will salute you JimsRebel !
Old 05-20-2010 | 08:38 AM
tnfarmer67's Avatar
tnfarmer67
i hooked up the gm 4 pin module and it fired up with ether but i cant get it to run off of the carb, gas is getting to the carb but not out of the jets ( from what i can see) i think there is a soliniod under the carb keeping the fuel from getting to the jets thanks jimsrebel for the help it was easy and cheap
xtal_01
12-02-2016 01:36 AM
bbf385
08-06-2014 06:23 PM
CWPottenger
07-20-2012 08:58 AM
Bovaloe
12-31-2009 06:45 PM
Cootvon
Bronco II
29
07-31-2007 04:56 AM
Quick Reply: tfi wire diagram
