adding cruise control
Old 05-02-2010 | 09:25 AM
rla2005's Avatar
rla2005
Originally Posted by wpbcobra
be for i buy a new master with the switch on it. dose anybody know if the truck would have the connector for the switch allready installed on the truck
You found the other wires, take a look around on the driver's side fender.
Old 05-02-2010 | 08:01 PM
wpbcobra's Avatar
wpbcobra
here are the wires i found are any of these the ones thank you for all of the help.
Old 05-02-2010 | 11:40 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Can you post or pm me vin
Because I have hard time believe that your XL F250 came with wiring for cruise control since I was hunt one on my 95 F250 and I don't see wiring like that pictures.
Only I see was AC plugs on my F250.
Old 05-02-2010 | 11:58 PM
wpbcobra's Avatar
wpbcobra
hey man here it is 1FTHX25HXSKA56382. Let me know if you find anything good lol
Old 05-03-2010 | 12:20 AM
Milwaukee1979F150
Ok try decode it doesn't tell much info
carfax show 17 records but need buy to see info.
I go check my F250 tomorrow if I see wiring like that. I need cruise control so bad.
Old 05-03-2010 | 12:28 AM
wpbcobra's Avatar
wpbcobra
lol me to i do most of my driving on the highway. that's way i am trying to find some way to install it
Old 05-08-2010 | 01:26 PM
wpbcobra's Avatar
wpbcobra
ok so i got it to work the plug in the 1st pic it the right one. all i did for now is plug the sensor in to test it and it works great now
Old 05-08-2010 | 04:31 PM
rla2005's Avatar
rla2005
That is great news.
Old 05-20-2010 | 10:38 AM
Milwaukee1979F150
Ok I got cruise control back in F250 it work
Question what pressure switch does do?
There are 2 way to disengage when touch brake.
I didn't use pressure switch I use jumper plug in and test touch brake it disengage like it supposed to be.
I never knew how it so easy to use at 65 mph and it doesn't use much gas compare to my foot that I got tired of drive slow on hwy to get money out gas tank worth.
wg112063
1999 to 2016 Super Duty
16
08-07-2023 09:25 AM
96_F250_Deezal
01-03-2018 11:25 PM
fordiesel69
2004 - 2008 F150
11-16-2017 09:40 AM
TKulak
01-17-2016 11:28 AM
Supercab
1983 - 2012 Ranger & B-Series
10-23-2014 07:06 AM
