1978 - 1996 Big Bronco
cold idle problems 1991 302 Bronco
Old 01-26-2003 | 09:16 PM
indysvodave's Avatar
indysvodave
Until a couple weeks ago, i could go out & start my Bronco up, and it would idle fast, until it got warmed up some, and then it would kick down to it's normal idle... Now, it won't fast idle, and will die. If I rev it up, it runs rough... Then if I let off, it will drop down and either die, or almost die & cycle up & down... I tried to pull codes, but can't make heads or tails from the beeps... Anyone know a common cause of this?
Old 01-27-2003 | 12:28 AM
nechun's Avatar
nechun
That is caused by a faulty iac(idle air control) valve. Also, clean the throttle plate. The iac you can find at any parts store. To make sure you get the right one, get the Ford engineering number off the part. It will probably be something like E7TF-9F715-A1A or some other variation.
Old 01-27-2003 | 01:24 AM
DeKuma's Avatar
DeKuma
I agree. It should be the IAC Valve. My 85 EFI, 87 EFI, and 95 EFI have all had the same symptoms corrected by replacing the valve.
Old 01-27-2003 | 07:59 AM
indysvodave
Thanks guys, I thought that it was probably the IAC too... I'll go get one today!
Old 01-27-2003 | 02:18 PM
indysvodave
Well, I got the IAC solinoid off...(the little part with the connector held on by 2 small screws) Is this what goes bad? or do I need to replace the whole IAC valve assembly? (the part this small part screws to)
Thanks again.
Old 01-27-2003 | 05:50 PM
Flash's Avatar
Flash
Dave, your Bronco is the same year and engine as mine. The IAC is mounted on the side of the throttle body where the 2 intake tubes come in. Take the entire unit off of the throttle body. I would suggest you buy the entire unit as the pintle in the vavle body is probably coked pretty bad. Replacing the IAC motor only most likely will result in an unsatisfactory fix and I'm not sure you can find the motor only part.
Old 01-27-2003 | 05:51 PM
steve83's Avatar
steve83
You'll be buying the whole valve & motor assembly, but you can't drive with it off - the engine won't idle down because of the MASSIVE vacuum leak. BTW How does it run with the motor off? The same? Be sure to clear the codes when you get the new one on - it'll probably be best to disconnect the battery for a few minutes to clear the computer's adaptive strategy since it's been learing how to work with that faulty IAC.
cweb
Bronco II
05-10-2012 07:14 AM
Daltongang
11-18-2011 03:30 PM
yankeerebel
11-14-2010 12:50 PM
truck_lover
Bronco II
05-30-2005 09:06 PM
tombob
01-17-2005 09:56 AM
