1978 - 1996 Big Bronco
engine block heater leaking coolant
Old 01-24-2003 | 07:52 PM
cyberdr2's Avatar
cyberdr2
Hey guys I have a question about the engine block heater on my 93' 5.8L Bronco. I was noticing today that there is coolant leaking from the block heater. Is there a screw that I can just tighten up? How hard is it to remove the element and replace the "o" ring? I was looking in my Haynes manual but it does not talk about it. Thanks guys.
Old 01-24-2003 | 08:57 PM
Mil1ion's Avatar
Mil1ion
There are different kinds but regardless,it has to come out to fix it.
There is an expandable type that bulges as you tighten the center bolt.
There is a butterfly fastener inside type that brings everything tighter as you tighten the center bolt.
You can try loosening a little at a time until you can twist and turn to remove it.
Or you can loosen it right up until it all falls apart and drops out.
Old 06-23-2010 | 02:14 AM
Alaskan 78 F 250's Avatar
Alaskan 78 F 250
We just replaced our block heater in our 94 Bronco with a 302 after the old one blew out accelerating onto the highway. Now the new one is leaking. Pulled the old, applied grease to the o-ring on the new, inserted, seated and tightened the butterfly screw. Did I miss something on the install? Anyone have this happen? Thanks
Old 06-23-2010 | 05:22 PM
Alaskan 78 F 250
Found it. Drained and pulled the new block heater and found the o-ring was nicked. Dang
Old 05-21-2017 | 11:03 PM
moriordan410's Avatar
moriordan410
I can't find where to plug it in on mine. Just bought it and I don't know where it plugs in. Any knowledge will help. Thank you
Supercab
16
05-02-2020 06:30 PM
f150crewcab
12-19-2018 06:48 PM
1972RedNeck
07-16-2017 10:29 AM
abe
05-21-2017 09:27 PM
lhud
12-23-2016 01:47 PM
