Another "truck won't start" thread
#31
PaysonPSD IS THE MAN! (at least I assume your a man). Got back to the truck this afternoon, took the cigar lighter out, plugged in the new fuse and got the OBD2 port working. I'm not a smoker so I'll track that short down a bit later.
I used the Actron Autoscanner OBD II Scan Tool (Model CP9575) and it appears to be working and reading Ford specific codes!
The menu system went through and asked me for vehicle info right down to the 7.3L diesel engine type. Got it at AutoZone and for far less than a AE with the Ford bundle. Not too sure but I think it does some testing too. I'll look into that later on as well.
These are the codes I pulled I don't think they are generic OBD2, but I could be wrong. Perhaps someone can confirm this. I copied them all down as desplayed on the unit:
P0476-Exhaust Pressure Control Valve Range/Performance
P1283-Injector Pressure Regulator Circuit Malfunction
P0236-Turbo charger/Super charger boost sensor A circuit range/performance
P1284-Integrated Control Panel Malfunction-Aborts Key On, Engine Off or CCT Test
P1501-Vehicle Speed sensor out of self test range
P0470-Exhaust pressure sensor A Circuit
P0566-Cruise Control Off Signal Malfunction
I hope this helps narrow down the issue so I can get working on the repairs. As always any assisitance is greatly appreciated.
Alex
![Warped Smile](images/smilies2/stretch.gif)
Alex
You really should clear that short to ground now. Might be a problem possibly causing some codes.
Your assumption is correct. I guess you didn't see my thread "My Shiny New Nuts With Pic".
![Smilie](images/smilies/happy0161.gif)
#32
Thanks PaysonPSD.
I cleared the codes. The truck started right up and now idles better than it ever has (suspect that's the CPS working correctly). But after about a minute, it shuts down as if the key's been turned off. The SES light came on for a split second just as it shut down, but did not stay on. I remember the same thing happened when the truck first left me stranded on the side of the road a couple of weeks back. The reader still indicates no codes read. Seems as though its something that's about to fail, but whatever it is, it hasn't given up completely.
Any ideas? What did the codes tell you? Are there any other areas that you would like for me to look into/check out?
Thanks again-looking at this as a challenge now.
Alex
Alex
#34
This DTC is very suspicious (P1283-Injector Pressure Regulator Circuit Malfunction) but you say that now when it dies you do not get any codes.
Can the scantool you are using data-log. If so, it would be nice to see what hapens leading up to the time it dies. ICP, ICP Duty Cycle while it is running and keep watching it until it dies. If the scantool does not data-log just watch these parameters and try to see what what happens to the numbers. Maybe this will help narrow down what is causing it to die.
#35
Thanks again PaysonPSD.
Don't have the manual or the scanner with me, but according to the website "It reads and displays live engine data". I'm not sure what it will display, but I don't remember seeing anything like "ICP" or "ICP duty cycle." I'll play with it some more tomorrow and report back.
#36
I would suggest a couple of simple tests to determine how well your scanner works. Unplug the ICP sensor and start the truck up. Check for codes. Do you get a P1280? Plug it back in and clear any codes. With the truck off, unplug the CPS and then crank as if trying to start the truck for 30 seconds. Do you get a P034x code?
If not, you're not seeing the diesel specific codes. Generic readers will still read generic codes on our 7.3 diesels. We just need to know what we can rule out based on what codes you are or are not seeing.
#37
![Frown](images/smilies/frown.gif)
BTW, no oil on the ICP sensor.
Put the ICP back in, battery charger and it started right up. Ran it a few minutes, 1000 rpm, 2000 rpm and it worked fine. Then the SES light flashed and it wanted to shut down again, but didn't. A few minutes later, another SES flash and shut down. After it shuts down it will start up right away-no issues then repeat.
No codes on the generic scanner.
No constant SES after shut down.
Checked the oil in the HPOP reservoir, about an inch or so from the top. BTW-make sure to put the plug back in before you start the engine-don't ask.
Am I going to need to go to the dealer to get the proper codes scanned?
![Real Angry](images/smilies2/mad.gif)
#38
Oh, and fill your crankcase oil back up if you tried to start with that little reservoir plug removed.
#39
It should start with the ICP sensor unplugged. Sounds like an IPR issue. Check the connector and wiring at the IPR. With the IPR connector removed check the resistance of the IPR coil. It should be approximately 10.5 ohms and the reading should be steady and not bounce around. The coil will slide off the IPR by simply removing the tin nut.
If I were you I would contact Actron to see if the CP9575 can read Ford 7.3 PSD specific codes. There is a Customer Service tab at this LINK .
This Actron video says that you may be able to enter the vehicle make, year and engine size. LINK It's a 7 and 1/2 minute video.
#40
The truck should start with the sensor unplugged. You did do the one on the front inboard side of the driver head, right? Try wiggling the wiring harness to the ICP with it plugged in and the truck running. Can you make it stall by wiggling the wires?
I also cleaned out the harness/connections just to make sure they were OK. On the outside they were pretty dirty, but the inside looked good.
Emailed Actron yesterday, hopefully they'll get back to me on Monday. The unit is odd. I remember it asking me a lot of info about the truck, now I plug it in and it just attempts to read the codes.
#41
#42
Alex
Alex
#44
Just talked to Actron and they gave me an explination of how their unit works. Here's how I understood it to work, or not, as the case may be...
Basically, they said that the unit isn't really intended to work on a diesel truck, more specifically a truck that's considered medium/heavy duty as those have different protocals. They said that their unit will pick up codes from the PCM, but that on diesels all codes are not generated or stored on the PCM. Many codes are generated from the Injector Control Module (?) and it does not always transfer the data/codes to the PCM. As a result, the unit will not be able to read the codes becuase it can only access the PCM. The ICM has the ability to turn on the SES light without letting the PCM know.
Any other ideas? I need the truck this weekend and I may bite the bullett and take it to the stealership.
#45
Gave up and took it to the dealership. I've only had this truck for a few months so I'm still getting to know it. When I purchased the truck I specifically asked if it had been tuned or if it had a chip-they said "no".
he dealer found a chip and said that it was malfunctioning and causing the no start issue. Took the chip out and they had to re-flash the stock computer. Had a few other things done and the truck runs fine now. Although seems like it has less power as expected. Right now I'm more interested in reliability than power.
In case anyone is interested it was a Hypertech. Seemed pretty old as some of the decals/stickers seemed very faded and worn.
