Fuel Return Line Kits (and viton o-rings)
Old 02-02-2010 | 11:25 PM
dyoung14's Avatar
dyoung14
Originally Posted by nappy nate
Set within 100 psi of each other new injectors, return kit,viton orings $285 shipped is what I was quoted by typ4 on OB.
yep i bought all this,. thats what i paid i dont think its bad for someone who stands behind the work and warranties it, mine has run great evern since, i just sent mine back to him to get them re set to a new psi
Old 02-02-2010 | 11:29 PM
starmilt's Avatar
starmilt
Well that would be at about 5% tolerances what kind of tolerance is new ones usually.
Old 02-02-2010 | 11:55 PM
nappy nate's Avatar
nappy nate
I don't know ,but I would guess that if a guy had a few new sets in front of him and a pop tester you could just match them to one another till you had a few 'balanced' sets without actually adjusting any of them.sounds easy while I type it anyway
nate
Old 02-03-2010 | 12:25 AM
starmilt's Avatar
starmilt
I hear you and I know they don't, but the manufacturer should be closer than 5%.
Old 02-03-2010 | 12:46 AM
dyoung14's Avatar
dyoung14
there is no way of getting them any closer than that, when you buy them from other places he seta them as close as he can get them which is within 100psi of each other,
the reason you cant get them any closer is cuse there is not shims availible to go any lower in psi, if someone were able to make the shims then it could happen
Old 02-03-2010 | 08:35 AM
WarOzz's Avatar
WarOzz
Shim stock is readily available at any machine tool store, with the use of a good gasket hole punch set shims can be made pretty easy.
Old 02-03-2010 | 09:39 AM
dyoung14's Avatar
dyoung14
then make some that will get the pressure down closer together then give/sell TYP4 alot of them and he can make his injectors even better for all of us
Old 02-03-2010 | 10:26 AM
WarOzz's Avatar
WarOzz
I did a search for him by user name and it come up blank?? Put me in touch with this guy and maybe I can help out.
From a mfg standpoint 5% tolerance is pretty high, I would expect better from a company like delphi.
Old 02-03-2010 | 10:44 AM
starmilt's Avatar
starmilt
Is he actually shimming them or just matching them up. I would think if you were phisically shimming them you should be able to get them very close. Dayum now I need a pop tester.
Old 02-03-2010 | 10:47 AM
WarOzz's Avatar
WarOzz
roflmao I was just googling how to build my own pop tester
Old 02-03-2010 | 11:05 AM
Cruickie's Avatar
Cruickie
Great info yet again! I'll have to look up this typ4 on Oil Burners.... I wasn't planning on doing the injectors yet, only at 126000kms now but they're certainly in the books. That being said though, that seems like a great price for the return line kit, viton orings and NEW injectors. Maybe I'll do it all at once! I am curious about that 5% tolerance thing though.... wondering if anyone can privide any tolerances from either a manufacturer or something as a comparison......
Old 02-03-2010 | 11:32 AM
starmilt's Avatar
starmilt
Yea that 5% bugs me that seems way high for matched injectors. I may be thinking wrong here, but if you bought 20 sets and can't match them closer than 5% I would be looking for a different manufacturer. I would like to see the manufacturer claims and specs. Matching them has been going on forever for years in the diesel world I just do not want to belive 5% is the best you can do at matching them, bit I could be all wrong.
Dave S uses Dps stage one and has been satisfied with them. The one and only time I was on oil burners some one claimed they were junk, because of the way they were modified. But in my mind they have been proven by Dave,so who knows.
  #28
Old 02-03-2010 | 12:50 PM
nappy nate's Avatar
nappy nate
star and warozz you need to do your homework before calling this gent out . 5% is not acceptable but thats what Ford gave us to work with , injectors that are set with shims. Sounds easy, just get other shims- uh huh good luck its been looked into quite alot by people more knowledgable than myself. This is I believe the stumbling block that has kept crossbones2 from 'super tuning' one of these motors with his glow plug method. Other style injectors have a dial to fine tune the settings, makes sense. shim style injectors are crap and meant to be thrown away and replaced every 100k. I got the old injectors in my Isuzu set within 3 psi of each other because they have a dial, with shims getting within 50 psi is considered nearly impossible even by experts.
nate
  #29
Old 02-03-2010 | 01:09 PM
starmilt's Avatar
starmilt
Nappy I am not calling any body out period. I would like to know what the manufacturers call allowable tolerances. That said if they are 20% and you are dealing with high volume sales and buy say 100 injectors at a time and pop test them all to match them. You should be able to get very close as far as matched sets goes some sets may be as far as 20% different as other sets, The bigger volume you have to work with the closer your match is going to be without ever reshiming an injector ever.
That said if your reshiming them you can take 8 injectors and get them very close but probably the time involved would not be worth it from a marketers standpoint.
  #30
Old 02-03-2010 | 01:31 PM
nappy nate's Avatar
nappy nate
Whats your definition of 'very close'?? Apparently the people who set these injectors consider 100 psi 'very close' and they have real world experience and put their reputation on this publicly. Get a pop tester and sell me some injectors when you get them balanced within 1%,I'll be your first customer. Maybe the reason why typ4 don't hang around here is because theres always somebody without a pop-tester saying that his tolerences are sub par , which is also known as 'talking out their ***'. I would also like to know what the manufacturers tolerances are as well, and the way it looks we cant really call them tolerances its looks more like a spectrum or a range..I asked typ4 to setup some injectors to 3 psi of each other and he had a chuckle and told me good luck and that in his opinion it was not possible but hey thats his opinion maybe someone else could do it better after they buy a pop tester/.
nate
Quick Reply: Fuel Return Line Kits (and viton o-rings)
