1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Missing Check Engine Light
Old 01-26-2010 | 03:56 PM
BenTheAdventurer's Avatar
BenTheAdventurer
I have a 1997 Expedition and recently noticed that when I turn on the ignition, every warning light on the dash comes on but the check engine light. I'm wondering if the previous owner cut a wire or something to disable the light. I've checked the fuse panel and it looks like all the lights are on the same fuse. Does anyone know which wires to check, or have any other ideas about why the CEL isn't turning on?
Old 01-26-2010 | 04:51 PM
cbradford's Avatar
cbradford
Maybe just a bulb is bad.
Old 01-26-2010 | 05:03 PM
BenTheAdventurer
You're right, it could be a bad bulb, especially if it was on for a long time and burned out. I'm hoping its not though, every time I've opened up a dashboard it was a real pain to get all the trim off.
Old 01-26-2010 | 06:56 PM
alloro's Avatar
alloro
Go to Autozone and get the vehicle scanned. The scanner will tell you if the light is supposed to be on or not.
Old 01-26-2010 | 07:10 PM
madsonp's Avatar
madsonp
Here's a procedure for removing your dash and cluster. It's not that difficult. Expedition
Old 01-26-2010 | 08:55 PM
alloro's Avatar
alloro
I agree and I was a bit surprised by the remark. From the time I say I need to take my cluster out, to the time it's out and in my hands is under 15 minutes. Oh well, to each his own.
nycstev
11-28-2012 01:56 PM
Comnt8r
1983 - 2012 Ranger & B-Series
08-19-2011 11:31 AM
Kmansinger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
11-25-2008 06:42 PM
jdschall
05-28-2004 04:41 PM
atikovi
09-09-2002 12:21 PM
