CCV Mod Trap
CCV Mod Trap
I was looking at building an oil trap for my CCV system when a friend suggested one of these. You could also add a pot scrubber inside the strainer.
Polypropylene Strainer, 1 in. dia., 80M - 2114114 | Tractor Supply Company
It opens easily without tools and you can buy replacement screens at ag supply stores. You can even get different mesh screens for it.
I don't know how oil resistant it is. The friend who suggested it has a backround in engineering if that means anything.
I used one. see this thread https://www.ford-trucks.com/forums/8...ml#post7268834 it is on a 6.0 but the traps work the same.
works fairly well, but I have mine plumbed back to the intake. It does leave a little mist, but not like stock. I'm gonna probably just buy the racor filter. I dont' know if I have more blowby (hope not, the oil cap on the filler neck trick says not too much) but my truck stinks with syn rotella. somebody else had a recent thread where they uses something similar, but it was a clear trap. looked pretty sweet.
found it. post 12 has a list of parts. https://www.ford-trucks.com/forums/9...donaldson.html
I think just draining the cup at every oil change should do the trick.
CrankCaseVentilation. Stock vents from valve cover right back into intake making an oily mess in the inter cooler tube and beyond. From what I've read the mod will remotely filter the oil mist and vent to atmosphere or back to intake. I read one that vented to the exhaust. Exhaust route Not recommended from the posts I read.
jasonfi
10-18-2014 01:07 PM
mrlightrail
07-09-2008 03:42 AM
ernesteugene
17
03-01-2007 04:49 PM
