Filling up oil filters
Old 01-18-2010 | 10:47 AM
FLYNNBROS's Avatar
FLYNNBROS
I put about 1 qt in mine
  #47
Old 01-18-2010 | 11:01 AM
mechelement's Avatar
mechelement
Would oil fill an empty, new oil filter when adding it to the motor before starting the motor? I don't know if that even really matters. I've never prefilled an oil filter before changing the oil on this truck for the first time. I prefilled it because folks recommended doing so.
  #48
Old 01-18-2010 | 11:09 AM
spdmpo's Avatar
spdmpo
Originally Posted by clux
You guys fill your air intake with prefiltered air after you change air filters too, don't you?
I use only sailboat fuel in mine.
  #49
Old 01-18-2010 | 11:15 AM
clux's Avatar
clux
Originally Posted by ron's power stroke
i believe they come with prefiltered air....
Do you know that for sure, because I heard the come filled with regular unfiltered air...............
  #50
Old 01-18-2010 | 11:23 AM
drillerdan's Avatar
drillerdan
I've always prefilled filters, don't know if it matters or not, just one of my little hang ups.
  #51
Old 01-18-2010 | 11:28 AM
Izzy351's Avatar
Izzy351
That's funny right there....
  #52
Old 01-18-2010 | 11:53 AM
ron's power stroke's Avatar
ron's power stroke
not sure on your 6.0 set up...but the AFE you need to push the nose of the filter down into the fender..this will push the filtered air into the filter..you just got to be a little quick at getting the filter onto the cone so the dust doesnt have time to get in...
  #53
Old 01-18-2010 | 02:18 PM
Fat Diesel's Avatar
Fat Diesel
Pre filler here. Maybe 80 times or so since I'm at 249k on the OD. We'd need Gene to provide a couple of pages of analysis describing in mathematical detail how well the oil film is clinging to each individual component based on it's composition and mechanical motion to say whether it's better to pre fill and have oil upon the startup or to no fill and run on film lube for that same time frame.
These engines are really tough. It's not going to matter IMO. I pre fill because that's what I was taught working on the 64 Falcon when I was 16.
  #54
Old 01-18-2010 | 03:59 PM
redfire42's Avatar
redfire42
I had to prefilter my winter air in my tires, wouldn't want a flat from the inside out.
  #55
Old 01-18-2010 | 04:11 PM
pmasley's Avatar
pmasley
You guys have been off your meds too long! LOL
JimJr15
11-02-2015 04:33 PM
jbomb007
07-31-2015 05:02 PM
2006White60
05-06-2015 11:52 AM
jonrjen
6.7L Power Stroke Diesel
28
04-18-2014 02:34 PM
dan66tampa
02-11-2005 01:16 AM
