FPR disassembled and this is what I found
Old 12-31-2009 | 02:08 PM
drivembig's Avatar
drivembig
I've been having problems with my truck as I have posted in a couple of other posts. I think I found my problem today. I took off the FPR and disassembled it and this is what I found.
This is the reglator disassembled
This is the port where you would typically do the FPR mod. Notice the black pieces of what seems to be some kind of plastic material.
This is looking down into the strainer that is in the bowl on the bottom of the regulator.
It was hard to photo all the debris in the last photo so I held the strainer up to the light and here is that photo. Notice that the part furtherest away from my hand you can't see any light through it. That is how full of crap it is.
This photo is looking up into the bottom where the strainer goes on and the bowl screws on over the strainer.
This truck only has 156000 miles on it and the fuel filter looked like crap. I guess the person that I bought it from just wasn't as honest about the maintenance as I thought.
I will have this all cleaned up and back on the truck later today and I will report back on how things are going.
Thanks for all the help and support that I have gotten from everyone here on my issues.
Old 12-31-2009 | 02:28 PM
79f-250custom's Avatar
79f-250custom
nice find! hope it helps the truck run better!
Mitch
Old 12-31-2009 | 02:30 PM
79f-250custom
accually from looking at that old rubber fuel line. you may just want to go the extra mile and take out the fuel bowl and replace all of those rubber fuel lines. when i did that to mine it helped the truck run a little better it seemed.
just my .02 cents.
Mitch
Old 12-31-2009 | 03:24 PM
Iallwork's Avatar
Iallwork
Nice post gave ya some rep points for that one. Found a couple black chunks in mine when i did the FPR shim. Probably should clean mine. Cheap fix. About all I can afford now anyway. Bored to death with this winter crap.
Old 12-31-2009 | 03:50 PM
Gobstopper909's Avatar
Gobstopper909
good stuff. hope all goes well for you. dont forget to check the condition of the fuel heater while the fuel filter is out.
Old 12-31-2009 | 06:17 PM
drivembig's Avatar
drivembig
UPDATE.....Truck prrrrsssss like a kitten now. Idles smooth, accels smooth, and no surging, no dieing when coming back down to idle as in slowing to make a turn etc. The plunger in the port where you do the FPR mod was stuck in there pretty good, so I guess the fuel wasn't really getting regulated. I've had this thing for a couple of months now and I thought it ran well when I got it, now I really think it runs well. It's dang smooth on the throttle now. Thanks for all the help.
Old 12-31-2009 | 06:23 PM
strokin'_tatsch's Avatar
strokin'_tatsch
guys with '96 and '97 trucks. notice where that long black piece is on his FPR??? that unscrews and then theres that little screen filter in there. if you pull your FPR off in that same spot as his last picture its got a snap ring and you pull that "plug?" outta there and there is a little filter in there too. it looks like steel wool just stuft down there. don't know how often they get dirty though. took the one on my dad's '97 apart with 147k miles and that piece wasn't dirty, but the FPR screen was filthy!!!
Old 12-31-2009 | 06:27 PM
pjwoolw's Avatar
pjwoolw
Nice work. Great pics of that early FPR. I was wondering one looked like on the inside. Probably one of the most ignored parts of the fuel system on these rigs. Reps sent!
Old 12-31-2009 | 08:24 PM
arkredneck's Avatar
arkredneck
mines coming off this weekend then any special o rings or anything to put it all back together?
Old 12-31-2009 | 08:35 PM
pjwoolw's Avatar
pjwoolw
New o rings would be a good idea. Diesel o rings or NAS has kits.
Old 12-31-2009 | 09:27 PM
drivembig's Avatar
drivembig
I checked with ford and they didn't carry anything at all. You can purchase the whole regulator or just the oring that goes between the regulator and the filter housing, the screen that goes in the same place. No aftermarket store like advance, autozone, or oreilys have anything at all. I was able to re-use all as they were in good shape, but looking at the debris inside it has to be from the insides of fuel lines comeing apart like was stated by 79f-250 above.
But, the truck is running sweeter than it has since I got it.
Old 02-27-2010 | 10:43 AM
fixitman1310's Avatar
fixitman1310
does the round black strainer cover screw out or is it pryed out. i pulled my fuel filter
housing/regulator assembly to look for cracks. i want to clean everything before
installing. thanx for any help 96 f250 ps steve in north carolina
Old 02-27-2010 | 12:30 PM
fixitman1310
i took mine apart. it looks much worse than yours. im cleaning now and hope it
will fix my idle problem. very good picts and write up thanx alot
steve n.carolina f250 ps
Old 02-27-2010 | 04:13 PM
IDMooseMan's Avatar
IDMooseMan
Cool...now I have another maintenance task to do. Thanks for the info. Sending reps.
muscletruck7379
Projects
41
05-05-2014 11:48 PM
pappakap
10-20-2012 03:58 PM
RAY1986F150
13
09-23-2012 01:49 PM
Fetch Em Up
Modular V10 (6.8l)
23
11-20-2009 02:42 AM
drivembig
Fifth Wheel & Gooseneck RV Towing
16
10-31-2009 11:43 AM
