real loud humming noise, HELP!!!!
Old 12-29-2009 | 02:46 AM
rambaseball45's Avatar
rambaseball45
ok, first off i have a 1997 F-150 4.6 with 205,000 miles on it.. stock engine and tranny. its been a great truck and never given me any major problems. But recently something under the hood (wish i could be more specific) makes a really loud HUMMING noise (almost sound like a trumpet). for example- say im driving on the highway and i let off the gas, this humming noise will appear and it is very loud, but right when i give the engine some gas the humming goes away. or also when im driving through town, when i come to a stop light, let off the gas to apply the breaks, this humming noise will come about. what i have to do is stick the truck in neutral and give it a big rev (which i do like hearig my exhaust so it isnt always annoying) and then it stops. note though, it doesnt happen every single time i let off the gas, however it is pretty frequent.
do yall think this is in the air intake system? thatd be my only guess because when i rev the engine it quits, but one thing is it sounds like it comes more from the passenger side of the truck, and it seems to occur more often when the temperature outside is cold. im completely stumped by this one, ive never heard anything like it. any ideas or info would be GREAT.
Thanks!!
Old 12-29-2009 | 08:21 AM
l-m tech's Avatar
l-m tech
SOUNDS LIKE THE PCV VALVE OR IDLE AIR CONTROL VALVE IS RESONATING
Old 12-29-2009 | 10:09 AM
steve(ill)'s Avatar
steve(ill)
yea, i think its vacuum related, thats why it changes with throttle position.
Old 12-29-2009 | 12:39 PM
rambaseball45
is this somethin i should be able to possibly fix myself??
Old 12-29-2009 | 12:40 PM
rambaseball45
ill ask you too, i know the pcv valve is an easy fix, what about the valve you mentioned?
Old 12-29-2009 | 12:53 PM
tomcat2zerozero's Avatar
tomcat2zerozero
humming noise
hey my truck did the same thing. it's the pvc valve. real easy replace.
Old 12-29-2009 | 02:58 PM
rambaseball45
if i aint mistaken, the pcv valve is on the right side of the engine??? which is where it seems to be coming from
Old 12-29-2009 | 05:29 PM
l-m tech's Avatar
l-m tech
THATS IT.STICKS OUT OF THE TOP OF THE VALVE COVER.YOU SHOULD BE ABLE TO SWAP IT OUT IN THE PARKING LOT OF YOUR FAVORITE PARTS STORE
Old 12-29-2009 | 05:35 PM
rambaseball45
you pretty much 100% sure??? thanks
Old 12-29-2009 | 06:19 PM
1975IH200's Avatar
1975IH200
Also could be a leak in the induction system, particuarlly in the air cleaner housing, inlet tube causeing resonance between the 'normal' air source and the leakage source,
Old 12-29-2009 | 06:44 PM
steve(ill)'s Avatar
steve(ill)
a bad pcv valve would be one good guess since the vacuum in it changes with throttle position..
Old 12-29-2009 | 06:49 PM
steve(ill)'s Avatar
steve(ill)
Old 12-02-2013 | 10:15 PM
hopperskins's Avatar
hopperskins
Wonder if the problem was ever found and solved. I've read about this since I'm having he same issue....replaced my pcv valve and that seemed to fix it only for a bit. Its still there just not as often. All the hoses/tubing seem in very good condition...any other ideas?
Old 12-02-2013 | 10:24 PM
pdqford's Avatar
pdqford
When its making that "mooseing" sound, unplug the IAC and see if it stops instantly.
Old 12-03-2013 | 11:36 PM
wyleone's Avatar
wyleone
I would start your own thread, this will keep this from getting confusing.
The original noise discribed and the way he stopped it was very telling to me. I'm surprised the fan clutch did not come up.
The PCV valve is common to make weird noises. As is the air intake for resonating in a moose type moaning noise.
erikc838
1999 to 2016 Super Duty
05-03-2017 02:55 PM
Jacob12635
1997 - 2003 F150
04-13-2016 10:27 PM
emiexco
03-31-2016 05:05 PM
buddy316
1997-2006 Expedition & Navigator
12-10-2015 10:12 AM
01 powerstroke
15
03-03-2011 11:27 AM
