Rough Idle and Stalling
Old 04-02-2000 | 06:09 PM
tech's Avatar
tech
I have a 79 Ford F150 XLT. It has been setting up for a while. When I start it now it idles rough. It will idle rough (not smooth) while it is cold but soon as it warms up it stalls. I can start it again but it will stall. I can keep it from stalling by pressing the gas pedal down and increasing the rpms while it is running. Any suggestions would be greatly appreciated? Thanks, tech
Old 04-02-2000 | 06:56 PM
78f100_1's Avatar
78f100_1
I'd be checking for vacuum leaks and proper choke operation.
Old 04-02-2000 | 07:55 PM
Nathan's Avatar
Nathan
You may need a carb rebuild. Arter sitting, the gaskets dry out and leak vaccume. Not to mention the varnish build up from the old gas sitting there. It needs to be done, so I would start there.
Nathan
Old 04-03-2000 | 05:26 AM
jowilker's Avatar
jowilker
