Oil pressure gauge erratic!!
Old 12-14-2009 | 04:53 PM
beanhead6D5's Avatar
beanhead6D5
On my way home from work today my oil gauge droped and the oil light came on.I pulled over to check the oil level.When I stopped the gauge went back up to normal and the light went out.The oil level was fine and the truck fired right up,no romps,no rough idle,everything sounded normal.
My question is were is the sending unit for the oil at???
I Think I have a electrial problem!I would like to see if there is a bad connection some where.
The last time I had this prob with a gauge doing this the pick up tube on the oil pump came loose.
Old 12-14-2009 | 05:07 PM
mueckster's Avatar
mueckster
Top of HPOP reservoir. Look under the bracket (in the first pic of your other thread).
Old 12-14-2009 | 05:45 PM
beanhead6D5
Thanks for the help Roland!!
I went and checked the connection and it was loose.Gave it a push and it clicked into place.ALL IS WELL!!
THANK YOU VERY MUCH!!!!
I must of had it apart when I did my RR.
Old 12-15-2009 | 12:21 AM
mueckster's Avatar
mueckster
No problem, Brad. Always ready to help a brother out. You'd do the same for me.
Polkster
06-17-2016 08:57 PM
Backdraft-14
61
02-28-2015 12:57 PM
thx997303
Modular V10 (6.8l)
01-06-2015 11:08 PM
Tasteslikeink
1997 - 2003 F150
03-22-2014 07:44 AM
TallPaul
Oil & Lubrication
09-15-2003 06:36 AM
Quick Reply: Oil pressure gauge erratic!!
