What is the lowest temperature I can shoot paint in ?
Old 12-03-2009 | 11:47 PM
ADSf100's Avatar
ADSf100
I need to shoot some primer and 2K poly and it's starting to get a little chilly.
Not the whole, just the engine compartment and interior.
I am using an HVLP setup.
What is the lowest (coldest) ambient temperature I can shoot in?
I can not heat up my work space so what other steps can I take to help with cold weather painting?
Thanks
Old 12-04-2009 | 07:41 PM
Bill W's Avatar
Bill W
I would not paint if it is under 50-55 degrees, using a fast reducer will help with lower temps.
Old 12-05-2009 | 02:02 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I'll add that is temp of the metal, not air temp. I do paint a bit in the winter, but it takes a long time to heat up the metal after getting the garage warm. I'll start heating the garage in the morning and paint late afternoon. With no heat in your garage, better wait till warmer weather.
Old 12-06-2009 | 12:43 AM
Sand_Man's Avatar
Sand_Man
Ditto. I try not to shoot under 60 degrees and actually prefer it to be 70 or so.
Old 12-06-2009 | 11:05 AM
Bill W's Avatar
Bill W
i agree 70 is just about right...higher temps and a slower reducer helps the paint to flow out... less orange peel.
FletchBzmMT
05-09-2017 09:19 AM
Green Streak
Paint & Bodywork
06-13-2016 08:47 AM
Chris Mason
1999 to 2016 Super Duty
20
03-01-2016 03:52 PM
RomeoKilo
6.7L Power Stroke Diesel
18
02-10-2016 04:41 PM
husky390
1997-2006 Expedition & Navigator
03-21-2015 11:09 PM
Quick Reply: What is the lowest temperature I can shoot paint in ?
