1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
V10 hard to start
Old 11-01-2009 | 12:50 PM
whitewing12's Avatar
whitewing12
V10 hard to start
I have a 2001 F250 V10 that is hard to start the first time I crank it in the morning. I have to step on the accelerator to get it to run. I have changed the plugs and the fuel filter. Any Ideas
Old 11-01-2009 | 02:17 PM
bubbasz1's Avatar
bubbasz1
IAC, Automatic Idle control, on the back side of the air box on top of the engine.
Old 11-01-2009 | 02:21 PM
Pinky Demon's Avatar
Pinky Demon
How's your battery doin'?
Old 11-01-2009 | 05:43 PM
whitewing12
The battery is new. Would the IAC need to be replaced or can it be adjusted. If replacing is the answer do you know the $ and is it a do it yourself kind of job? Thanks for all the info!
Old 11-01-2009 | 06:20 PM
bubbasz1's Avatar
bubbasz1
You replace it, I rate it as an easy, 60.00 at autozone.
It doesn't sound flooded or something weird in the morning it justwon't catch until you give it some throttle and it will start and then idle.
AutoZone.com | | Idle Air Control Valve | THROTTLE AIR BYPASS VALV
Old 11-01-2009 | 07:09 PM
whitewing12
yup, thats exactly what its doing thanks for all the help!
Old 11-17-2009 | 01:03 AM
Racing Larson's Avatar
Racing Larson
I have a 99 f350 v10 and it's doing the samething as the other guy but the only question i have is would it still be the iac if it will start sometimes and other times it will be just turning over for a minute then start? I think it's the iac but just checking?
Old 11-17-2009 | 01:13 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, check your IAC. Clean or replace as needed.
Will Poole
06-04-2016 01:19 AM
dcchadwick
04-25-2016 08:53 AM
Uncle Meat
Modular V10 (6.8l)
08-14-2015 10:40 PM
redbandit98
Modular V10 (6.8l)
29
11-10-2014 07:29 PM
kameronth
Modular V10 (6.8l)
04-02-2011 01:31 AM
