75 F250 axles in a 79 F250
Old 10-05-2009 | 12:59 AM
johnboy427's Avatar
johnboy427
I am looking at some axles a D44 and a D60 rear out of a 75 F250 and was wandering if they will fit in my 79 F250 that also has a D44 and a D60. I think I am going to pick them up if they will work or not because they are cheap, but I would like to swap them because they are 4.10s and I have 3.54s, but if I remember right the D44 is closed knuckle low pinion and I really don't want a down grade. So what are the axles? Are they a down grade? Will they even fit, isn't there a frame change between high and lowboys?
-Johnboy
Old 10-05-2009 | 04:35 AM
75F350's Avatar
75F350
-Johnboy
The front will fit, but as you have aready suggested the front axle is a drum brake closed knuckle, low pinion axle. Probably has external locking hubs as well. For sure a complete downgrade from your current front axle.
The rear will not be as direct a bolt up. The frames were narrower on the 73-77 F250 4x4's and the spring perches will have to be relocated to accomodate the differences.
This is not an expansive upgrade. The front can be changed to the desired ratio and the rear can be upgraded to a larger / stronger axle for less money than a ring and pinion swap.
Old 10-05-2009 | 08:21 AM
Broncoholic1's Avatar
Broncoholic1
[quote=75F350;8001068]The front will fit, but as you have aready suggested the front axle is a drum brake closed knuckle, low pinion axle. Probably has external locking hubs as well. For sure a complete downgrade from your current front axle.
@x Complete downgrade do not do it. Wait & get a set of 77.5 -79 F350 60's. I waited for a year before I found mine.
They are still out there.
Old 10-05-2009 | 01:43 PM
johnboy427's Avatar
johnboy427
It does have some warn premium hubs on it, and the main reason I am buying them is because they are $50 for the pair. I will save them until some one with a high boy need a spare, or if the ring and pinions are good I might just pull them out and install them in my truck, after all I can get both complete axles for 1/4 the price of one new ring and pinion set. I was pretty sure what they were but wanted to be sure. Thanks
-Johnboy
Old 10-05-2009 | 01:56 PM
montana_highboy's Avatar
montana_highboy
50 bucks is a steal for the pair, while the rear R&P set will work in your axle the front R&P set will not, you'll need a "reverse cut" R&P gear set for your HP44.
Old 10-05-2009 | 02:11 PM
johnboy427's Avatar
johnboy427
Well it sounds like both plan A and B are kinda screwed, but for the price what the heck the hubs cost more than the axles do. Hey montana you get any snow last night?
-Johnboy
Old 10-05-2009 | 02:19 PM
montana_highboy
The mountains (above 6,000 ft.) picked up a few inches over the last few nights but so far the valleys are dry, won't be long though.
johnboy27
1999 to 2016 Super Duty
11-07-2013 02:11 PM
johnboy427
08-16-2009 10:03 PM
johnboy427
Engine Swaps
05-17-2009 06:49 PM
johnboy427
04-29-2008 06:25 AM
johnboy427
10-03-2006 03:10 AM
Quick Reply: 75 F250 axles in a 79 F250
