license plate light problems
I bought a 99 F250 from a friend of mine and he told me the license plate light needed to be replaced. I checked the fusebox and everything was good, so i bought another light and bulb. I cut the wires into the old housing and wire-nutted the new housing to it, which is identical. Now I have no dash lights and my tail lamps do not work. Brake lights and headlights work, but nothing on the dash or parking lights. Ive checked bulbs and fuses and everything. I even reattached the old light housing and pigtailed it and the same problem continues. Any tips before I get the meter on it and try and find a short? Any help would be awesome!!
Thanks
Thanks
All the "running" lights are on the same fuse. You haven't looked hard enough for a blown one yet.
Or, you've blown that part of the rotary switch open in the headlight switch assembly.
Remember, there are two fuse boxes on these trucks. Get out the owner's manual from the glove box, or did your friend throw that away?
Wire nuts aren't a very good way to splice wiring on a motor vehicle, BTW.
Pop
Pop
99 Ford Ranger 4cyl 5 speed .... Dash,tail lights and lights to radio and AC controls do not work...
mxdadof2
Electrical Systems/Wiring
07-31-2015 12:25 AM
jhweigel
01-05-2015 04:02 PM
1999Expy
1997-2006 Expedition & Navigator
09-29-2014 12:23 PM
