esof vacuum solenoid test
Hello...new to this forum and have already learned alot by searching archives, great site!
The four wheel drive is not engaging on my 1997 Expedition 5.4 liter.
Transfer case works, the problem is the vacuum motor (on the front axle) is not getting vacuum. I am replacing the vacuum elbows at the vacuum motor (diaphram) which were bad. The vacuum motor itself works well when vacuum is manualy applied.
My question is how do you test the solenoids?...I found the terminals supply steady 12 volt flow to both solenoids when the key is on, regardless of the switch position (2, a4wd, 4H). Is this normal? Does the GEM interupt flow to the solenoids to activate them and apply vacuum or should it be the opposite?
What is the procedure to check the function of the solenoids? Or should I suspect the switch?
Thanks,
Kevin
Thanks,
Kevin
Thanks,
I just confirmed the solenoids are functioning correctly by pulling the pink and blue lines at the solenoid with the motor running. Vacuum was as it should be in the various positions of the switch.
I'll pull the entire vacuum lines now, there is no vacuum at the opposite end. My problem must be damaged lines...like so many others who have had axle engaging problems!
I hear there are lots of issues with the selector switches on those. Are you seeing the piston move in and out on the diff when you change the selector? If not, trace the vacuum lines back and disconnect at the coupling near the passenger wheel well and put a vacuum gauge on them. They should change when going from 2WD to 4WD. If it looks good, I guess you could check the resistance on the switch. I could ask my buddy if he remembers what they were.
EDITED: *****Sorry, just saw your post! I left to get a few beers and talk with my neighbor while I was typing!
Now that's cool!
I took my expy down to my farm and drove the 8N up out of the bottoms. Just when I got down by the River the rains came. Boy was I glad the 4WD is fixed. I went through plenty of mud when I retrieved the truck.
We are going to mount some flashing ambers for legal road driving (my house is about 1 mile away by road) and an implement light.
The site I got info from for the restoration is ntractorclub.com. Good folks there. Thanks for posting the pics.
I'm glad you got your 4x4 fixed. Here's a couple of sites for parts for the old tractors if you're interested. This first one is where I order most of mine through mainly because they're in Washington state, and I'm in Montana so shipping is real fast. Plus they have a real good selection. http://www.ytmag.com/store/index.htm Here's another one that is more for the 8N. http://ford8n.com/f8shop/index.cgi?ID=X5AJS2 Also there's a bunch of stuff on ebay for these. If you're interested in converting yours to a 12V system, here's a site that has a good write up on how to do it. I highly recommend doing this, it sure makes a big difference, and if you keep all the 6V stuff you can always easily change it back to original if you want. http://home.earthlink.net/~8ntractor/12volt.html
Would like to see information on how the EOF system works including the electrical and vacuum aspects. I have vacuum leaks in Hub and solinoid. Replaced solinoid only to discover it was not working. Checked electrical and made the following discoveries. There are three wires. The center wire was 12V. Tried grounding to no avail. But then grounded solinoid wires seperately and made the following measurements. Three wires: Middle Green/pink always hot at 12V
Toward rear: Red; Toward front Gy/Black or maybe white black
Vacuum readings: NO grounding = 0 psi
Rear wire (red) = 7 psi
Front wire (wh/bk) = 3 psi
Combined grounding = 14 psi
I do not know of these are expected outcomes. One video I saw suggested 4 X 4 vacuum about 20 psi, and a lower vacuum for when in 2 wheel drive.
My next steps are to figure out what controls the ground lines and see if I can fix the electrical. I would appreciate any insight and suggestions.
