Let me see your alternative interior lighting setups!
Old 10-01-2009 | 07:49 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
Originally Posted by Alvin in AZ
Well, heck, buy her some dangged flowers, you big dummy! :/
Alvin in AZ
In my case, that hasn't worked often with women...how's it supposed to work with a giant cobra?
Old 10-01-2009 | 08:44 PM
Jermafenser's Avatar
Jermafenser
The most effective interior mod I've ever done.
100% portable, powerful light, no need to worry about wires, and it's adjustable from flood to spot.
Yes, I'm serious.
Old 10-01-2009 | 11:47 PM
Dirt racer's Avatar
Dirt racer
I just looked at the factory wiring diagrams for a 75 F-100 and I was wrong. Told you it had been a many years. Lol The dome light is grounded on the other side of the light and 12 volts positive goes through the door switches. It's a 15 amp fuse on the stock fuse box. I installed an aftermarket fuse box and rewired everything myself for my truck. Had a bad engine fire. I have a rear utility light so I believe I took power from that circuit so the mirror light switch would work with the doors closed. That runs off the same fuse. F3. I think running off that circuit for your led lights would be ok, unless you run a lot of stuff off you cigarette lighter. It looks like that runs off there to.
Old 10-02-2009 | 04:58 PM
Bowtie_Schmowtie
Could it be done with a constant hot and grounds at the doors? Or would having two grounds still cause too much power draw? I would think that with a 15A fuse in the hot line, it would not be an issue...but I don't want to find out the hard way.
I don't run anything off of the cig lighter. It is not even hooked up...it's just filling the hole in the dash.
Chad, I like the simplicity of your idea...my cousin has the same setup in his '01 F250 Powerstroke...but having to get in the cab to find the light to be able to get in the cab is something of a self-defeating strategy. Besides, his batteries are always dead...when he even remembers to put the light back in his truck.
Old 10-02-2009 | 05:38 PM
Alvin in AZ's Avatar
Alvin in AZ
Amazon.com: LRI PWK Photon II LED Keychain Micro-Light, White Beam
The older I get the dumber I get. :)
Also the crummier my eyes are getting at seeing dimly lit stuff.
Alvin in AZ
Bowtie_Schmowtie
147
02-18-2014 08:35 AM
Bowtie_Schmowtie
01-11-2011 03:16 PM
Bowtie_Schmowtie
24
07-05-2010 04:57 PM
Bowtie_Schmowtie
05-18-2010 10:41 PM
Bowtie_Schmowtie
50
08-14-2009 08:35 PM
Quick Reply: Let me see your alternative interior lighting setups!
