Urgent.
#46
#47
so for the life of me ... there are 6 bolts in total which I cant get off for the life of me get off (4 of which are on the driveshaft which I have soaked in pb as well now ... )
and
anyone have any ideas on what I can try ? ive tried the wrench trick, ive cut off the head off one of my old wrenches and put it in a pipe, still no luck .. I cant fit an impact socket on there ...
and
#48
#50
think a small propane torch will do ? because that is the only option I really have at this point. I've soaked the front driveshaft with pb blaster lastnight after work and today before work ... so hopefully when i go home thatll budge .. if not not too big of a deal because, I just want this TC off ... ill worry about the rest later.
this project seems to be dragging on almost though, I only spend about 1-2hrs a night on it for the last 2 days (this is day 3) so ...
#51
I don't undersand the problem to be honest. You ought to be able to break the head right off of that bolt by putting some grunt behind it. The bolt doesn't look mangled, so wrench slipping does not seem to be the issue. Just get a 6 point box end wrench on that thing, put a cheater on it, and either turn it or break the head. If it breaks you can deal with extracting the thread later.
And a propane torch will be a waste of time. If you want to use heat, you are going to need oxy/acc with a pin point tip and a carburizing flame.
#53
chances are good that the threads will give before the bolt does... and if not, you needed a new one anyway.
You are turning them CCW, correct? (always have to make sure, sometimes things get confusing when working upside down)
Avoid that Oxy/Acy torch...it'll warp or melt that Aluminum before you know it.
I'd say just throw that pipe back on that wrench, and pull down with everything you've got, with the longest lever-arm you can... it may only break for 5 degrees at a time, but get it moving and it'll be easier.
#54
rightie tightie - leftie loosie
yeah, they definately do get confusing ... If I got confused I would just insert a bolt back in, and double check.
so really at this point for me then just go the brute force method and go to town ?
doing so on the case doesnt scare me as much as doing that on the front driveshaft ...
#55
#56
#57
#58
A hammer is definitely important when using PB. It vibrates what is siezed just enough to help the PB penetrate that extra thousandth of and inch. We use this method all the time on my ship, because many times a torch is not a possibility due to flammables being nearby.
Use brute force, if you break it, oh well.
Happens all the time and you will just have to replace it.
Personally, I would use PB, a hammer, AND the torch, but that's something I am very comfortable with.
#59
Get a 6 point before you round anything off.
