how can you guys turn the fuel up so much?
Old 08-21-2009 | 12:38 PM
Diesel_Brad's Avatar
Diesel_Brad
Yes, they are the plate that the bumper brackets bolt to. Now you have to take some metAL AND MAKE 90* bracket to bolt to that and that bolt to the stock front bumper.
  #62
Old 08-21-2009 | 02:27 PM
johnboggs21's Avatar
johnboggs21
Originally Posted by 84 f250 6.9
are these the brackets?
Take a torch and blow them welds off
  #63
Old 08-21-2009 | 02:31 PM
Diesel_Brad
And what will that do?Other than make him have to weld them back on! The holes are in the plow frame by your hand to bolt on bumper brackets
  #64
Old 08-21-2009 | 02:37 PM
johnboggs21
i didnt tell him to cut the bracket off. I said blow the welds off.
  #65
Old 08-21-2009 | 03:44 PM
84 f250 6.9's Avatar
84 f250 6.9
sounds like I'm goin bumper huntin'! I agree the welds look like poop but the whole setup is solid
  #66
Old 08-21-2009 | 11:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
From what I remember of our Western plow bracket, that does look like it has been broken and/or modified several times.
The 6" height is a pain off road, but if you make it any higher one plow end or the other will not touch when you angle the plow.
Also a higher hitch point makes the plow want to dig in instead of gliding over the surface.
  #67
Old 08-22-2009 | 01:42 PM
84 f250 6.9
well id rather make money than go muddin so ill leave the height alone but ill be searching for a front bumper
  #68
Old 09-01-2009 | 06:29 AM
volumetricefficiency's Avatar
Originally Posted by bud48fla
I also have a reworked intake manifold.
do you have a picture please?
  #69
Old 09-04-2009 | 01:07 PM
JoeDaf's Avatar
JoeDaf
Can you turbo a 6.9 diesel?
  #70
Old 09-04-2009 | 03:33 PM
84 f250 6.9
yeah for bout 2 grand new you can turbo .. or find a kit on ebay
  #71
Old 09-04-2009 | 11:25 PM
Dave Sponaugle
JoeDaf,
Welcome to FTE and the IDI diesel forum.
A 6.9 is just begging for a turbo.
Well, any NA diesel is just begging for a turbo.
  #72
Old 09-05-2009 | 12:03 AM
JoeDaf's Avatar
JoeDaf
can it hold up
Will the bottom end hold up?
  #73
Old 09-05-2009 | 01:29 AM
David85's Avatar
David85
HELL YES!!!!!!!!!!
The bottom end of the engine not only has massive true 4 bolt main bearing caps, but the caps themselves are so massive that they re enforce the block it self. Have a look at this:
We do know of a 6.9 IDI that was built for drag racing and made 1500Hp. Supposedly, the problem they had with the block was the core plugs would fall out from the flexing and vibration. Bottom end failures have happened, but I never heard of one happening below 600Hp unless it had underlying problems.
6.9s get turbocharged more often than you might think and they hold up just fine if you stay below 10 PSI. Above that, head studs are advised to prevent head gasket leaks.
  #74
Old 09-05-2009 | 05:16 AM
joe f350's Avatar
joe f350
that ur motor dave
  #75
Old 09-05-2009 | 01:16 PM
David85's Avatar
David85
Yes it is
