need help removing crossmember
I am trying to remove the transfer case cross member on the donor truck. I want to change the np 203 to a 205 and use the donor trucks crossmember for the 205. the trucks are highboys. my problem is I got all the rivets out and could move the crossmember in the frame but can't twist it to remove it. any tricks anbody got help is needed.
