2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Bubbling Paint
Old 08-07-2009 | 06:47 PM
thinksnow's Avatar
thinksnow
Ok I have some pics, how the hell do I post them?
Old 08-07-2009 | 06:51 PM
berry1234's Avatar
berry1234
Add them to your Gallery. Goto User CP, then Edit Gallery.
Old 08-07-2009 | 08:06 PM
thinksnow's Avatar
thinksnow
Pics
I put two in my gallery. What a pain in the a**
Old 08-07-2009 | 08:10 PM
shorebird's Avatar
shorebird
Add the photo to your gallery.
Return to the forum thread you want to post the picture in.
Open another browser window.
Go to FTE.
Open forums.
Click on "Edit Gallery" in the left column.
Select edit for the album the picture is in.
Pick the photo and click on [Forum Codes - For displaying image in forum posts]
Copy the url from the insert that opens.
Do that by highlighting the code and then clicking CTRL and C at the same time.
Return to the original window where you are at the thread where you want to add the picture.
Click "Go Advanced"
Click "Insert Image"
Add the img code by clicking CTRL and V at the same time.
Click on OK.
That will add the image to your post.
Old 08-07-2009 | 08:19 PM
Beechkid's Avatar
Beechkid
Originally Posted by berry1234
Yep, the old bubling paint. The paint warranty is 12 months or 12,000miles for defects, and 5/60 for rust that has eaten through the metal. You probrably fall in between like 99% of people with this problem. Can you post some pictures of the problem? I would still talk to your dealer. If they are nice they may fix it.
The 12/12 warranty only is in reference to shine/fade, etc. I believe the peeling/bubbling paintis covered by the 7 year warranty (like my 1990 F150 was that had bubbling paint on the cab in 1995- Ford repainted the entire cab, the dealer covered expenses to repaint the entire bed)
The bubbling is an adhesion issue and covered by warranty. The adhesion failure is linked to the color being applied before the primer has adequately cured (common mfg issue with laytex paints)
Old 08-08-2009 | 10:47 AM
thinksnow's Avatar
thinksnow
I went to the dealer this morning. They said it would be covered under the warranty. The body shop is closed on saturday so my wife has to bring it back Monday to have it photographed and schedule the repair. I want to know how they plan on fixing it. Are they going to just try and repair the two small spots or are the going to strip both panels to reseal,reprime and repaint them correctly?
Old 08-08-2009 | 10:22 PM
hookd's Avatar
hookd
good luck with them trying to do anything correctly our dealer tried to fix our flaking paint with that touch up crap you get out of a fingernail polish bottle man was I pissed when I saw that they eventually saw the light and repainted the door but I still don't thing they did a very good job
Old 08-09-2009 | 12:03 AM
Beechkid's Avatar
Beechkid
The Ford TSB requires the entire panel to be sanded down to bare metal and repainted. They should do what use to be called a tape test, where an adhesion test is conducted on several spots on the vehicle, this will be the actual determining factor of what gets painted. in my case, there were spots on the front end and roof, so Ford paid to have the cab and front end repainted.
I spoke to the paint shop mgr myself and asked the following questions (now bear in mind that mine was a 1990, bright regatta blue that was 5 years old and sat out in the sun)...
1. I would prefer laytex paint is not used on my truck. I would be willing to pay for the extra cost for urethane. Answer- We are going to paint it with urathane because we don't want it back with any problems.
2. While I'm sure you guys are good at color matching, i do not want this truck coming out like a Zebra- I would be willing to pay for the cost of materials to paint the bed as well- if you guys would cover the labor (since it would be cheaper than color sanding the paint). Answer- We already thought about that and have enough $ in the budget to paint the entire truck.
Old 08-09-2009 | 08:26 AM
thinksnow's Avatar
thinksnow
I specifically went to this dealer because they have there own body shop on premises. I plan on being very involved in their decision making process.
Old 08-10-2009 | 02:57 PM
mylo's Avatar
mylo
I wonder what this is covered under. Must be the 3 year 36 thousand warrentee. I have the same problem with my 2007 expedition. I bought it pre-own certified....50,000 miles, took it home and noticed it. I brought it up to the dealer and they said it wasn't covered. I wasn't very happy because with the certified vehicle I did not check things over that closely because I thought it would be covered. I guess we live and learn. I have not had it repaired yet...mine is on the tail gate. Wondering how long I should wait. Will waiting cause any additional issue? The quote from the Ford body shop was for 550.00. Does this sound reasonable? Mine was white also...seems that alot of the white ones have this issue. Good luck.
Old 08-10-2009 | 03:22 PM
thinksnow's Avatar
thinksnow
Yes, its the 3/36 warranty. Its not covered by ESP either. You have to be within the 3/36.
Old 08-10-2009 | 05:10 PM
RED DOG DADDY's Avatar
RED DOG DADDY
dude you have no idea where this thing is headed. document EVERYTHING. my 08 expy started with a bubble then 2 repaints 2 trips to bbb well here see for yourself ""if you want to see what these butchers are all about go to http://www.floridafordbuyersbeware.com/"
  #28
Old 08-10-2009 | 05:17 PM
RED DOG DADDY
ps. hood and tailgate are alum....mine is black (check out the pics on my site) ford factory spec on paint mills 3-3.5 mine had 14-14.5 about4 or 5 coats...they repainted it same thing 14-14.5 mills..and again still14-14.5 mills...betcha carl demuth bodyshop mngr from jarrett ford plant city fl. wished he never gave me the inside scoop on paint millage........chuck
  #29
Old 08-10-2009 | 08:37 PM
thinksnow's Avatar
thinksnow
WOW it appears they let a class freshman from the spec. ed vocational school paint your truck.
  #30
Old 08-21-2009 | 12:29 PM
thinksnow's Avatar
thinksnow
Does anyone know the TSB# in reference to the bubbling paint repair?
Quick Reply: Bubbling Paint
