Locate Vin Number on 1965 Ford
Old 07-22-2011 | 09:50 AM
Builder X's Avatar
Builder X
65 Mercury 250 Frame VIN location - Help
I am having trouble finding my frame VIN, sanded some areas off similar to Carras' locations and no luck yet. How big are the characters, is the whole vin number stamped on and does it run in the same direction as the frame? Just not sure exactly what I am looking for.
Thanks
Wes
Old 07-22-2011 | 11:06 AM
stumpy0227's Avatar
stumpy0227
frame VIN
i had to take my fender and inner fenderwell off my truck to find it, and i found it only after using a wire wheel on my drill, to get the years and years worth of rust off! mine ran the same way as the frame itself, and looked like this=* F10 JK 376230 * had to look VERY closely, to see some of the characters, but they were there!
Old 07-22-2011 | 11:07 AM
stumpy0227's Avatar
stumpy0227
oops, i forgot! i found mine on the RIGHTSIDE frame rail, about halfway between the radiator core support, and the firewall on the cab! basically, right behind the shock mount! good luck, and God Bless!
Old 07-22-2011 | 11:08 AM
stumpy0227's Avatar
stumpy0227
VIN number was ALSO on my "warranty tag" riveted to my driver's door, but you cant go JUST by that, because they might have changed the door out, so the VIN wouldnt match up!
Old 07-22-2011 | 11:15 AM
Builder X's Avatar
Builder X
Frame Vin
Thanks Stumpy0227, that's good to know and that it is hard to see. I will keep sanding and remove the inner fender as well.
Old 07-22-2011 | 12:58 PM
stumpy0227's Avatar
stumpy0227
you are welcome, and btw, my name is Donny, lol these guys on here helped me to find mine, too! they sure know their stuff!
Old 07-22-2011 | 02:28 PM
Builder X's Avatar
Builder X
Frame VIN
Thanks Again Donny. Yes FTE is a great site with a lot of knowledgeable guys, I have learned a lot in a couple of days!
Wes
Old 07-22-2011 | 05:30 PM
jowilker's Avatar
jowilker
Wes, It is on the passenger side rail in two places, runs lengthwise and maybe 1/8" stamp numerals. Once under the cab and out in the engine bay.
I don't know if a mirror and a light would help or not.
The tag on the door is good only if it is original. Mine is not and is registered by it. My title & door tag sez F25 my chassis F10.
John
Old 07-24-2011 | 08:41 AM
66f100's Avatar
66f100
12 years ago i painted my 66 and i had to replace the drivers door, went to sell the truck over the weekend and the vins dont match . i see where they say the vin is on the frame pass side by the crossmember or under the cab. i have cleaned all the frame around the crossmember and cant find it.where under the cab could it be? I have to find this and get this figured out. im going to dmv tomorrow and see what they say. Im in iowa but the guy that was buying it lives in ill.he said its a nightmare with this stuff overthere. thanks for any help
Old 07-24-2011 | 09:04 AM
carras's Avatar
carras
most people find tthe VIN forward of the engine crossmember/coil springs on the pass. side frame rail. I happen to find my VIN just behind the cross member. I posted a picture of my location in post #12 of this thread. The VIN under he cab on mine is consistent with where others have found theirs. Good luck
Old 07-24-2011 | 10:10 AM
66f100's Avatar
66f100
is it under the cab and by the crossmember? 2 locations on the frame and where do i look under the cab thanks.
Old 07-24-2011 | 06:41 PM
carras's Avatar
carras
Both locations are on the top of the frame. Go look at the picture in post #12. The sandpaper pieces are placed on both locations. I was not able to access the VIN under the cab without lifting or removing the cab. Hope this helps.
  #28
Old 07-24-2011 | 09:19 PM
66f100's Avatar
66f100
found it in front of crossmember and it matched the title. thanks for all the help
  #29
Old 07-24-2011 | 10:31 PM
carras's Avatar
carras
66f100, glad to hear it all worked out.
  #30
Old 07-25-2011 | 06:23 AM
jowilker's Avatar
jowilker
Knew you could do it.
John
