2nd MC & Booster Issues
Old 07-23-2009 | 12:28 AM
Jermafenser's Avatar
Jermafenser
If the fluid shoots up when you step on the brakes, you have air in the system.
Old 07-23-2009 | 07:10 AM
gtuttle's Avatar
gtuttle
When putting these together I noticed the pushrod but no adjusting screw, is there any pictures showing where this is. Sorry for being stupid on this it is my first time dealing with mc & boosters.
thanks
Old 07-23-2009 | 09:45 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Hmmm... the end of the pushrod that goes against the master cylinder should be able to thread in and out.
Josh
Old 07-23-2009 | 09:50 AM
gtuttle's Avatar
gtuttle
did not know that thanks, evidently it can be turned by hand clockwise & countercloackwise to go in & out in length.
thanks
Garry
Old 07-23-2009 | 11:00 PM
Jermafenser
How'd you adjust the pushrod? If I remember right, you need some sorta cardboard gauge from Ford.
Old 07-23-2009 | 11:25 PM
maskedman's Avatar
maskedman
He can make a gauge out of cardboard.The width needs to be cut to the size of the span between the studs and the make a cutout to the depth posted above.Adjust the head on the plunger to just touch the top of the cut out.Needs to be done with plunger pushed into the booster.
Old 07-23-2009 | 11:31 PM
Jermafenser
Sounds about right. Now that I think about, I probably need to adjust mine...(put in a M/C recently).
Old 07-24-2009 | 07:16 AM
gtuttle's Avatar
gtuttle
greta ideas
thanks
Garry
dwstenersen
18
03-16-2017 01:29 PM
Dave145
25
10-03-2016 08:32 PM
F-250 WARHORSE
15
08-09-2016 09:51 PM
eatont9999
16
11-18-2011 12:31 PM
gtuttle
26
07-22-2009 08:13 PM
Quick Reply: 2nd MC & Booster Issues
