Previous owner bent the stick shift
Old 07-12-2009 | 06:11 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Originally Posted by Ford Super Duty Man
No, actually its bent up
Well, that is weird. I'd hit the junkyard and try to find a replacement. I wonder how/why the hell that happened?
Old 07-12-2009 | 08:59 PM
Ford Super Duty Man's Avatar
Ford Super Duty Man
Old 07-12-2009 | 10:42 PM
9.ford.5's Avatar
9.ford.5
holly f**k, bent? more like obliterated
ive seen bent shifter but not anywhere near that bad....they would have to be pretty damn freaky to bend it like that
Old 07-12-2009 | 10:47 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Wow
they are really thick it impose to bent until it have torch heat to do that. My guess that owner have long arm or try carry 3 passengers so shifter hit #2 passenger legs.
jimistephen's Avatar
jimistephen
That really looks like it was on purpose. I was thinking the other day that I wish mine was bent like the old ones from the t18, where it goes up a little then back and then up again so the **** is closer to you with out hitting you.
Old 07-12-2009 | 11:23 PM
9.ford.5's Avatar
9.ford.5
yeah i agree...i had mine out and while i didnt try really hard i did attempt to bend it with no luck, pretty much need heat to successfully bent it
Old 07-12-2009 | 11:26 PM
Ford Super Duty Man
how do you get the shifter out of there. I found a junkyard truck with one but could not figure out how to get it out
Old 07-12-2009 | 11:28 PM
bonzi88's Avatar
bonzi88
If the shifter isn't hitting the dash...leave it. My 5-speed shifter hits the center console in reverse. Probably modified to clear middle passenger.
Old 07-12-2009 | 11:35 PM
regulate34's Avatar
regulate34
pull the boot off and you will be looking at the top of the trany
their will be 3 torques head screws i belive T25 or T30
take them off and make sure the trany is in neutral
and is will just pull out
its simple
but make sure the trany is in neutral
Old 07-12-2009 | 11:37 PM
regulate34's Avatar
regulate34
oh sorry
i am telling you how the take the whole fork and piviot ball along with the shifter seat bushings
which is alot easyer than trying to seperate the two parts
Old 07-12-2009 | 11:38 PM
Ford Super Duty Man
its simple
thanks for that info
Old 07-13-2009 | 08:43 AM
regulate34's Avatar
regulate34
i knoiw this because i went thru the same **** mn my truck the previous owned did a hack job on the shifter to acommodate the 3in body lift
and i pulled it out in reverse it took me 2 days to figure out how to set it back to neutral witha screwdriver and flash light
Vegas Ernie
1983 - 2012 Ranger & B-Series
12-06-2013 03:50 PM
audimotion
6.7L Power Stroke Diesel
18
08-08-2012 08:30 AM
scottlane
05-10-2007 11:06 PM
Champ
2004 - 2008 F150
17
03-11-2007 11:04 PM
broncobasher
06-06-2004 07:52 PM
Quick Reply: Previous owner bent the stick shift
