1997 F450 Ambulance Project
Ok, I thought that if the sealant wasn't factory, then there was a chance it had been rebuilt since the intake manifold wouldn't need to be removed otherwise. Does the oil pan use the same sealant? It amazes me that they didn't just design it to have a gasket of some sort.
Yep. The same stuff. At least I think so. There are a couple of different sealants Ford used. Both gray in color. Again this is off the top of my head from what little research I've done.
Ok, Its most likely the original motor then. It also has a solid flywheel and I thought most 1997 had the dual mass. The F-Super Duty/F450 must have been the exception. Thanks for the help and information.
I did a little more this weekend but unfortunately I dropped a valve cover bolt down the intake. took me forever to get it out. Magnets or vacuum wouldn't get it so turned the engine upside down and it still didn't fall out. Finally blew some air in there and it fell. Other than that I spent time prepping for paint. Picked up the primer and hardener but I'm still undecided on a color. Most likely a dark silver or gray.
Thats the thing, I did have everything covered but while prepping it for a little touch up paint, I was straightening out a small bend on the top of the intake manifold and another on the rear of the valve cover. To straighten the valve cover, I had to remove one bolt. I placed the bolt on top of the hoist, fixed the dent, then I removed the tape that was covering the intake on the passenger side to fix it. After a little straitening, I leaned over to get a better look. My hand hit the valve cover bolt and it fell perfectly in the 2" intake hole of all places.
Tell me about it. It would probably be easier and cheaper to pull the whole motor than to remove the head if it had to be flipped. I could have probable gotten it our right side up though if it came down to that.
while the 390 was on the engine stand my ex knocked a nut/bolt tray off a shelf and some of it fell down into the engine. she got all freaked out and didnt know what to do. i assured her it would be fine and she didnt have to tell him about it. once he got the engine put in and fired it up, lets just say it didnt last too long lol. to this day he thinks his cat knocked the stuff off the shelf.
Good story phillips91. To funny.
#28
its for sure a '96 or '97 engine the 94.5, 95, and some early '96's had the EBP sensor behind the HPOP and higher up, your is down low and in front of the HPOP. also the later engines had 10 bolt intakes the early's had 8. your looks like it has the 10's.
the year is irrelevant, there all internaly the same 94.5-97. the higher HP rating was all done via the PCM.
what is your PCM code by chance? it will be real easy to read with the fenders off.
Good luck on the project. I love the interior of the old ambulance.
Diesel Rod
Diesel Rod
Last edited by 444dieselrod; 09-16-2009 at 01:05 AM. Reason: spelling, I failed english......
#29
Thanks 444dieselrod. I'll check the pcm this weekend. The intakes are 10 bolt and I'm fairly confident that this is the original motor.
I'm still not sure about the flywheel though. Didn't 98 models and prior have the dual mass flywheel? Was the F450 an exception? Is my flywheel an aftermarket and what clutch to buy?
#30
