DP Tuner and ZF6 manual question.
Old 06-16-2009 | 10:03 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
This is an exact repost of what I wrote in the SECOND post of this thread:
Originally Posted by my dumb ***
There are a couple of tuning tricks that are at work here. One is the low boost fueling and the other is MAP transfer.
In a nutshell, the PCM is "seeing" less boost than what is actually there (MAP Transfer) and is not commanding much fuel to be injected due to the low boost fuel values.
For example, when you have low boost conditions such as 0-5 PSI actual, the PCM is only "seeing" 0-1 PSI. Certain values in the low boost fuel table are similar to stock.....which means LESS fuel until you get a few more PSI of actual boost.
However, it certainly is nice to not have to worry about overboost defueling.
Why does nobody even READ these posts?
Oh yeah, we're all too busy trying to figure out what sensor is bad.
  #47
Old 06-16-2009 | 10:10 PM
4inchlovin's Avatar
4inchlovin
Im just glad other people are having the same exact issue as i am. I know its not a sensor because if it was it would throw a code. It has to be either a compatibility issue or a programming issue.
  #48
Old 06-16-2009 | 10:24 PM
westarms's Avatar
westarms
If it is the MAP sensor then I have a bad one and my father has a bad one also.
I switched them out after your first post and saw no difference in the performance.
I tried that before I contacted Jody or Clay.
I do appreciate the help though.
I started a long thread on my first try!
I feel all warm and special!
  #49
Old 06-16-2009 | 10:35 PM
4inchlovin's Avatar
4inchlovin
LOL! It is not the MAP sensor. What is your PCM code???
  #50
Old 06-17-2009 | 09:01 AM
chayes01's Avatar
chayes01
I'm having the same issues as everyone else. My PCM code is XPC4/DAC3. Should each of us contact Clay or Jody? I know they're watching this thread or should we wait until a fix is in?
  #51
Old 06-17-2009 | 10:09 PM
westarms's Avatar
westarms
My PCM is APX1.
I emailed Jody but have not called, their website says they are closed to calls this week and I am respecting that.
I can let every one know what he suggests.
(I still need to try Clay's suggestion also)
  #52
Old 06-19-2009 | 09:41 AM
SailCO26's Avatar
SailCO26
Ok, can now add my initial $0.02 here.
[Yes, I got my DP installed last night - woo hooo!
https://www.ford-trucks.com/forums/8...ks-thread.html]
So far I've only clocked my test spin and the commute to work today, so have only messed with 80E and Decel.
While I'm in complete agreement that the kick-in-the-a$$ doesnt drop in until around 17-1800rpm (and when that happens... HOLD ON!), I'm not convinced that the lower end is any worse than stock. Mine's always been a bit of a "dog" below ~1600rpm with a load, which I found surprising as I've always thought diesels were known for low-end performance.
Drive in today on the highway (80E) looks like the EGTs are just a touch higher than stock, and the OBD is reporting lower boost than the gauge sees - but the boost is definitely higher than stock (70-75mph ~21-2200rpm). The couple of hills/acceleration from traffic I dealt with letting the rpms drop <1500 seemed about the same as stock from SOTP.
Will work with 80T next weekend with the camper in the mountains and report back again.
  #53
Old 06-19-2009 | 11:04 AM
wla6518's Avatar
wla6518
subscribing - I have similar symptoms in he 80E tune.
All of the others seem to work great. I currently do all my driving in 60E.
  #54
Old 06-19-2009 | 01:55 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
That therein is the "problem". It's not so much a problem as it is a tuning change. I think we're all in agreement now on this issue. If anyone else questions it as being the tuning.....well, it's beyond me.
  #55
Old 06-30-2009 | 10:12 AM
chayes01's Avatar
chayes01
I've been following this thread as I'm having the same issues but there hasn't been any updates recently. Has there been any progress on getting this issue resolved?
  #56
Old 06-30-2009 | 04:10 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Is this happening from a dead stop and in 1st gear? I never had a manual with a diesel, but I have had plenty gas engines with manual shifters. I could always get some RPM's up then pop the clutch and get the tires spinning.
Bump.
  #57
Old 06-30-2009 | 04:17 PM
4inchlovin's Avatar
4inchlovin
Even if you dump the clutch at a high RPM it will go on its face before it starts to accelerate when it is in a tune. In stock if i dump the clutch at a high rpm it takes off or at least spins the tires.
  #58
Old 06-30-2009 | 04:51 PM
miller_feed
That does seem strange to me. Maybe someone going to the East event with a 6sp can show Jody what is happening. I had the oppisite happen to me after my injector install. My pedal was so responsive, I couldn't drive it in town. With live tuning he had it running the way it should.
  #59
Old 06-30-2009 | 05:04 PM
Bigcat350's Avatar
Bigcat350
I don’t have this issue; my truck has good pedal response for a big old truck . But it seems a lot do have it.
I would think the tuning could be adjusted for this if that’s indeed the problem. Like Rick said maybe someone can show Jody at RRE and he can correct it.
  #60
Old 06-30-2009 | 09:42 PM
Stewart_H's Avatar
Stewart_H
Bump.
I drove Nolans truck on Sunday, and I tried to do that very thing. I raised the RPM's and dumped the clutch and nothing. It just slowly pulled forward, gradually building speed.
So, I tried it again, feathering the clutch, letting it slip first gear to try and take off fast, like you might do while drag racing, while still trying to keep traction, and again, nothing. It just falls on its face and then gradually builds speed, slowly gaining momentum.
Stewart
