replacement frame
replacement frame
Hello all,
I am planning on rebuilding one of my trucks starting this fall. However it kind of all will fall apart if I can not find a better frame. I live in wonderful North East Ohio and the road crew here uses salt in the winter like its the only thing they can use. I have two trucks here and plan on using all the good parts off both truck to make one. However one is 4x4 the other is 4x2 and the 4x4 frame is in very poor shape. I would like to find a good solid and pretty clean as far as rust and that goes.
So I'm looking for a company that would not only have a frame for a 1991 F250 4x4 standard cab 8 foot bed, but would be able to get it to me? I do not have a truck right now that I can drive over a great distance to pick it up with a trailer.
Thanks,
Thanks,
the F150 is a coil spring front suspension and the F250-350 are leaf spring... the difference being in the location of the spring perch and shackle mounts... plus the F150 and light duty 250 frames are a bit lighter, I think the F250hd and F350 are heavier gauge steel and maybe heavier x-members... or so I've been told.
If you can find your way out to the west, there are thousands of solid, rust-free truck frames sent to the shredder every year. There are simply too many of them to save.
An F-250 frame is much stronger than an F-150 frame. If you plan on using your 3/4 ton truck like a 3/4 ton truck, you will be shopping for another frame in a few years.
try here. Marshfield Truck Parts - Your One-stop Shop for Southern, Rust-free Truck Parts they are a little to far from me
BDawg171
19
01-27-2010 07:19 AM
