1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Will 08 mirrors fit on my 04?
Old 05-12-2009 | 09:57 PM
h0rs3p0w3r's Avatar
h0rs3p0w3r
I have a 2004 F250 Super Duty with the regular style mirrors and I'm looking to upgrade to the towing mirrors and like the look of the 08 ones. I'm not planning on hooking up the power mirror part because my truck now doesn't have power mirrors, but I am planning on hooking up the turn signals by just tapping into the wire somewhere. What I am unsure of is will they mount up to my truck the same, and if not, what are my options?
Old 05-12-2009 | 10:02 PM
UGA33's Avatar
UGA33
Yes, they should mount up.
Old 05-12-2009 | 10:06 PM
Greg B's Avatar
Greg B
I do believe that the mounting is the same.
Old 05-12-2009 | 10:17 PM
Fordfanatic4life's Avatar
Fordfanatic4life
there are several BB members who have already done it...
it fits the door opening perfectly..
the only issue is wiring but since u said u dont have power mirrors your really laffing...
p.s. good call on the 08 mirrors, they do look good even on the non-08 trucks..
Old 05-12-2009 | 10:25 PM
Greg B's Avatar
Greg B
And you can see better with them over the 99-07 trailer tow mirrors. The spot mirror is almost worthless on the 99-07 mirrors. Way better on the 08 SD mirrors.
Old 05-13-2009 | 12:00 PM
Downriver Thunder's Avatar
Downriver Thunder
I disagree. I use mine plenty and find them very helpfull. Did you ever try adjusting them?
Old 05-13-2009 | 12:01 PM
Downriver Thunder
Also, those mirror will not fit and you should just send them to me instead.
ha ha Just kiddin'
Old 05-13-2009 | 03:13 PM
Greg B's Avatar
Greg B
I adjusted the spot mirrors more ways than a country boy can pick a banjo and I could not elininate the blind spots to my satisfaction. I had to install some C-Better spots to make them good. It seems the height of the factory spots was insufficient. The 08 spot mirrors are taller and seem to have the blind spots covered much better than the earlier ones. The 08 mirrors are also or seem a little wider. At any rate, for what I like they are proportioned better.
Old 05-13-2009 | 05:59 PM
h0rs3p0w3r's Avatar
h0rs3p0w3r
Thanks guys. That will probably be my next mod. I just need to get up the money, they're expensive and I'm not going with one of those knock off eBay garbage mirrors. Got me an 08 bumper in the mail as we speak. Looking forward to that too.
Old 05-13-2009 | 06:26 PM
juneau76's Avatar
juneau76
I hear you on this. Consider getting them from Ed (FTE/PARTS-GUY) when the time comes (if you haven't already obvously).
Old 05-13-2009 | 06:29 PM
h0rs3p0w3r's Avatar
h0rs3p0w3r
How do I go about that? I'm new here.
Old 05-13-2009 | 07:00 PM
juneau76's Avatar
juneau76
He's at FTEPARTSGUY.COM. Here is the link to the mirrors: Th!nkPartsGuy/FTEPartsGuy
Oh, and welcome to FTE!
Old 05-13-2009 | 07:05 PM
h0rs3p0w3r's Avatar
h0rs3p0w3r
I appreciate your help. And thanks a lot. Been here two days and already had a few things answered. Hopefully many more to come.
Old 05-13-2009 | 07:55 PM
riggz's Avatar
riggz
Theres a how-to in the Super Duty tech folder. I suggest browsing it since you are new.
And yes, once you use the 08+ spot mirrors you will see how crappy the previous spot mirrors are.
Old 05-13-2009 | 09:26 PM
Fordfanatic4life
agreed on the 99-07 spot mirrors.. i think they are to small to use quickly/safely..
i added convex round mirrors to the larger portion.. i dont even look at teh little factory spots anymore...
just couldnt get em set to were i felt safe using/trusting em..
Quick Reply: Will 08 mirrors fit on my 04?
