1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Retrofit a back up camera?
Old 05-04-2009 | 10:28 PM
skl's Avatar
skl
I have an early job 1 and missed the option of a back up camera with the display in the mirror. I tried one from Costco which didn't work and wondered if anyone has retrofit the factory unit or if the price would be prohibitive???
Sure would make hooking up the trailer a lot easier!!
Old 05-05-2009 | 01:13 AM
Hunter40's Avatar
Hunter40
Yes, I bought the mirror off the internet and a rear camera that is on the license plate frame. From the inside you get the same picture minus the distance bars ford added. On the outside you can hardly tell the camera exists. I hooked the switch to an upfitter instead of reverse so I can turn it on to check on the hitch and wiring while travelling. Hope this helps.
Old 05-05-2009 | 07:43 AM
skl's Avatar
skl
Thanks- remember the site you got it from?
Old 05-05-2009 | 12:22 PM
Hunter40's Avatar
Hunter40
Backup Camera System, Rear View Camera Mirror
Got both this mirror and the camera from this site. The mirror is the same company that makes them for Ford so it looks identical. There are several options for the camera based on what works for you.
BTW- I can hitch up by myself the first time every time! It's great.
Hunter40
Old 05-05-2009 | 01:55 PM
WhëëlMå1's Avatar
WhëëlMå1
moved to Super Duty
