Motor mounts?????
#46
#49
#50
The heavy battery cable runs to the starter, then the relay controls the solenoid on the starter. What the deal is, the starter draws too uch power to run through the ignition switch, so the ignition switch controls the relay, which then controls the starter solenoid. Basically, the wiring goes: Batter to relay, relay to solenoid energizing wire. Big eyelet on the relay, small eyelet on the starter, about a 12 gauge wire. I had to do this on my cummins since the ignition switch was dropping too much voltage to energize the solenoid on the starter, had intermittent starter problems until zI put the realy out there like this arrangement.
#52
You have to use the feed from the ignition to control the relay before the starter of course. The original starter solenoid for the gas motor would be hooked up just like it was for the gas motor, and the wire that would have gone to the starter on the bolt tab now goes to the small pin on the diesel starter. Yes, it's that simple....
#53
ok the glow plug relay is wired up, and i took one of the wires that went to the gas relay on the small post "S" and put it on the glow plug relay to give it power, now i wired up the gas relay with the battery cable to one side and the small cable to the small post of the starter and the "I" cable to small post of relay, and another battery + cable to the + post of the starter. Is that correct??? because it doesnt do anything, and when i put the keys in the ignition everything workd in my truck, lights dash and etc, but when i turnd the key to start it everything shut off and nothing workd after that. im CONFUSED
#55
Well, it seems right ... batt to big lug on one side of the relay, other big lug to small lug on diesel starter, battery cable direct to the big lug on the diesel starter. Question: do you have a ground cable to the motor securely, as well as one to the body? Have you tried jumping the relay to see what happens? Have you verified you have 12 v getting to the relay from the ign switch, or that 12 v is getting to the starter?
Oh, and had to work today, as do many of us, so we can't always be here...
#56
#57
ok, and i dnt know if i mentioned it or not, i have a Allison at545 hooked up to the 6.9, and i bought a gear reduction starter and it has a +post and a -post and a little post, does the wiring change??? and on the gas relay i have a red wire and a brown wire that went on the "S" and "I" post, which one is the one i will use???
#58
The relay will be hooked up just like before, except maybe the wire that went to the safety switch might not be used, as you no longer have that trans. I believe it is the red wire that is supplied 12 v when turning the key. It sounds like you may have a different starter than what we use.
#60
