Vacuum and smog mess.
Old 05-08-2009 | 10:03 AM
AbandonedBronco's Avatar
AbandonedBronco
Good work! Which carb did you go with?
Old 05-10-2009 | 07:48 AM
tcbofade's Avatar
tcbofade
It's a Carter YF one barrel that I purchased second hand from another FTEer.
So far, so good!
Old 06-21-2009 | 04:41 PM
napoleankjj2006's Avatar
napoleankjj2006
i have a 86 f 150, the smog pump and a/c pump are gone. i have replaced, the tranny filter, tranny mount, both motor mounts, cap, rotor, plugs. i rebuilt the carb but it still uses gas. also put in new tranny fluid. when i shift my truck into gear, the truck idles rough until i get it going and its ok. when i put it in to reverse it slams hard and when i put it in to drive its smoother. could it be avaccum leak casusing the slamming into reverse?
the carb still smokes. are is there something i can do to fix my truck.
Old 06-21-2009 | 04:43 PM
napoleankjj2006
also i have no tail pipe but the cat and muffler are still there but the donut between the exhaust manifold and the cat and muffler is gone so there is a gap between the two
Old 06-21-2009 | 06:32 PM
AbandonedBronco
First of all, replace that donut. I would guess a wager that that is what you're seeing smoking. That's a lot of space for exhaust to be coming out. (I imagine you have a lot of noise too.)
How does the truck idle when it's in neutral? Which transmission do you have? I'm guessing the C6 3 speed auto. If that's the case, there's just one vacuum line to it. If you think it's a culprit, just replace the line. It's cheap stuff, and better than guessing. My brother's C6 had a 1" long hole in his vacuum line and it wouldn't shift at all, so leaks do quite a bit.
It also sounds like you're on the right track with all the stuff you've replaced.
PS: If you figure out how to rebuild a carb that doesn't use gas any more, you'll be rich.
Old 06-21-2009 | 07:40 PM
napoleankjj2006
its a c6 auto tranny. when i put it in park and neutral . it idles good, when i put in drive or reverse, it shakes like hell until i hit the gas and get it going. which side of tranny is the line on. i put it into gear and the truck shifts bsckward or foward.
Old 06-22-2009 | 09:49 AM
AbandonedBronco
I'm not sure what side it's on, but it should be the only vacuum line going to the transmission from the engine. However, the vacuum only tells the transmission when to shift, not what selection to put it into (like D, 2, 1, R, N, etc.) If you're having issues with the shifter, your shift linkage, or the transmission itself is having issues.
If your engine idles smoothly when in neutral, that means your engine is running pretty nice. Your transmission seems to be more of a culprit.
BTFordGuy302
18
06-07-2015 08:26 AM
Soarer
08-18-2014 06:19 PM
KsCop
35
08-11-2014 04:25 PM
Bugzturbo
28
06-28-2014 03:32 AM
friction
08-07-2013 07:53 PM
Quick Reply: Vacuum and smog mess.
