92 f350 electrical problems
Old 04-05-2009 | 03:42 PM
aljen466's Avatar
aljen466
I just picked up a 92 f350 460/e4od and am having some electrical issues that have me stumped. First, no check engine light- I've checked the all the wiring, the relays, fuses, even pulled the cluster out to make sure the bulb was good. Second, no overdrive circut- the wires coming out of the shifter were damaged, I repaired them and still no improvement. The o/d off light wont come on and the truck wont shift into overdrive. Third, no cruise control- just figured that out, haven't started to check it yet. Finally, my power locks will not work- all of the wiring appears to be good, fuses etc........ I'm leaning towards a bad computer, but would love any suggestions. Thanks for any help.
Old 04-05-2009 | 08:00 PM
dustybumpers's Avatar
dustybumpers
power locks not in the computer, I'm thinking bad fuseable link or 2. you may also want to take your seral # to ford there was a recall on ignition switch,and cruse control. both went bad, and could cause a fire. the recall may not have been preformed. even though it's un related, I think there was also a recall on a check valve for the fuel pumps too,
chuck1058
10-19-2014 05:22 PM
mcdavidson
10-08-2014 03:24 PM
DAVID'S97F250HD
08-04-2010 02:42 AM
Daugh20
1997 - 2003 F150
12-18-2009 12:00 PM
2ktrott
1999 to 2016 Super Duty
11-30-2007 10:08 AM
